Keyframing a nest of multiple clips
I have about 30 clips in a nest. It’s a stop motion star.
I’m trying to slowly zoom out of the star without having to manually go in and change each tiny half second clip.
I want to start at scale:10 and end up around 7, then I will repeat this on the next nest from 7 to 5, and so on and so fourth till the morphing star goes out of view. at the highest point there are 11 different clips going at once.This can easily turn a whole days work into minutes if it is possible.
I would greatly appreciate any help.A fool sees not the same tree that a wise man sees.
-William Blake
