Activity Forums Apple Motion Keyframing
  • Keyframing
    Posted by Clay Coleman on November 18, 2013 at 10:06 am
    Coming back to Motion after awhile. I’m having problems getting used to the way keyframing works in v5. Is there a way to turn it off completely? I’m constantly having to delete unwanted keyframes or create unnecessary layers to make the simplest tweaks and adjustments.
    Seems broke… or what is the recommended way to work efficiently without automatically creating keyframes at every touch of a font size, color, position, or any other keyframable parameter?
    Alex Udell replied 12 years, 10 months ago 2 Members · 3 Replies
  • Alex Udell
    November 19, 2013 at 4:01 am
    And slipping clips with Keyframes is changed now too…
    major pain in the butt…..
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Alex Udell
    November 19, 2013 at 9:30 pm
    Well, I’m coming from Motion 3 so….
    in 3, if you had keyframes on a object
    and you slipped the the media via option drag….
    the media would slip, but the keyframes would remain in place.
    Now….the keyframes slip with the media slip.
    I can see instances when this would be useful….but more often than not…
    I’ll place media build some motion and then want to refine the edit (content of the video) but not the timing of the animation….or I’ll be replacing media when reusing a previously built animation. this becomes a major annoyance in those cases.
    Alex
  • Alex Udell
    November 21, 2013 at 1:03 am
    Done Sir.
    Alex Udell
