Activity Forums VEGAS Pro Keyframing
  • Keyframing
    Posted by Dirk Wellekens on November 11, 2011 at 1:11 pm
    I want to have a text pop up on the screen (from the bottom) and then disappear again. I used to do this this in Vegas 9 using keyframes and it worked just fine: 3 keyframes, text at 3 positions and done.
    Now I am doing my first project in Vegas 10. I do the same (except I have to select “animate” now to have the keyframe window). In the preview in the placement tab I get what I want, but on the timeline I get no text at all. What am I doing wrong?
    Dirk
    Frederic Baumann replied 14 years, 10 months ago 3 Members · 3 Replies
  • Theo Van laar
    November 11, 2011 at 11:01 pm
    If you upload your project (.veg) file, (without footage), we can have a look what’s going wrong
    Theo
  • Dirk Wellekens
    November 12, 2011 at 6:40 pm
    The problem seems to be solved, although I don’t know why. I think I am doing the same things as before, but now it seems to work
  • Frederic Baumann
    November 15, 2011 at 10:31 pm
    Couldn’t it be that you had a zoom applied in the work area, making you believe that framing was OK, whereas in fact, it wasn’t?
    My 2 cents,
    Frederic
    Want to Match Colors between clips? new plug-in here.
    Check GPU-powered FBmn Software plug-ins to fix White Balance and Exposure issues.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
