Activity › Forums › Maxon Cinema 4D › Keyframing
  • Keyframing
    Posted by Dan Brock on February 19, 2010 at 2:30 pm
    I’d like to know how to copy an objects position keyframe from one frame to another.
    Example: I have text that makes a move on it’s (z) axis from 15 to
    30 frames, I want to keep that keyframed postion until frame 149,
    then rotate the text on it’s (y)axis from frame 150 to frame 160.
    Sounds easy enough, but I’m having a little difficulty copying frame
    position (30) to frame position (149).
    Thanks.
    Adam Trachtenberg replied 16 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    February 19, 2010 at 9:28 pm
    In the Timeline you can control + drag a keyframe to copy it. That’s probably the easiest way.
