Activity Forums Adobe After Effects Expressions Keyframes with Expression
  • Keyframes with Expression
    Posted by Duane Walters on September 10, 2020 at 12:33 pm
    I create lower thirds all of the time.
    Often times I use a simple expression to either hide/show the subline depending on if there is text present in the subline or not…easy enough.
    That looks something like this:
    if (thisComp.layer("subline").text.sourceText.length >0) {
    55
    } else {
    100
    This time, I’m trying to make the headline scale down if there is a subline present, but I’m getting a pesky “expression result must be of dimension 2, not 1” error.
    Does anyone have any suggestions?
    Declan Zimmermann replied 6 years ago 2 Members · 1 Reply
  • Declan Zimmermann
    September 10, 2020 at 1:32 pm
    Assuming you are applying this expression to the Scale parameter, you need two dimensions, as scale has both x and y properties. So try:
    [55,55]
    } else {
    [100,100]
    See if that fixes it. Slight Smile
