Activity Forums Avid Media Composer Keyframes w/ Color Corrector
  • Keyframes w/ Color Corrector
    Posted by Jordan O’leary on January 19, 2006 at 8:06 pm
    Avid XPress HD 5.0 WIN XP
    Is the keyframs for color correction, it doesn’t seem like their is. I’m just trying to do a simple effect to where the highlight gradualy flare out all the way to white, like a flash. I use levels in FCP but and I can see that I can do it with the color corrector but I can’t put GD keyframs on it in Effects mode. I make the adjustment, witch to effect mode, put my first key fram, go back in color correct mode, adjust, then I try to put another keyframe in on effect mode…. nothing…. it all white…. ?
    Rob Alexander replied 20 years, 7 months ago 2 Members · 1 Reply
  • Rob Alexander
    January 19, 2006 at 8:17 pm
    no keyframes I’m afraid. Break up your clip with add edits then colour correct the bits so that they progressively get to the effect you want and add dissolves between the effects.
    good luck,
    rob
