Activity Forums Adobe After Effects Expressions Keyframes offset and duration expression
  • Filip Vandueren
    July 4, 2023 at 1:42 pm
    Do you want to actually move the keyframes with a script, or have the dynamic result of it, using an expression ?
  • Otávio Nascimento
    July 4, 2023 at 1:48 pm
    Just the result with an expression
  • Dan Ebberts
    July 4, 2023 at 2:44 pm
    Something like this should work:
    L = thisComp.layer(index-1);
    t1 = L.inPoint;
    t2 = L.outPoint;
    t = linear(time,t1,t2,key(1).time,key(2).time);
    valueAtTime(t)
  • Otávio Nascimento
    July 4, 2023 at 3:10 pm
    That worked perfectly!
    Is it possible to change the keyframe value with an slider?
  • Dan Ebberts
    July 4, 2023 at 4:51 pm
    It’s easy with linear keyframes, but it can get tricky if you have custom easing that has to be preserved. Depends on what you’re doing, exactly.
