Activity Forums Maxon Cinema 4D Keyframes immovable on timeline
  • Adam Trachtenberg
    July 12, 2015 at 3:53 am
    If you right-click in the time slider you’ll get a popup menu. Go to the Options submenu and deselect “Advanced Mode”.
    That said, you can select the keyframes in advanced mode, but you have to do it by Shift + dragging a selection.
  • Dylan Hall
    July 12, 2015 at 5:50 pm
    Thank you so much! 🙂
  • Michael Forno
    July 13, 2015 at 5:31 am
    If you use the default workspaces like I do you can try resetting it. Cinema 4D normally uses the defaults and the horizontal timeline is the default I believe. Seems basic I know but sometimes the only way to fix something is to reset it.
