Activity Forums Adobe After Effects Keyframes going negatives
  • Keyframes going negatives
    Posted by Kuljeet Singh on April 21, 2016 at 9:03 am
    hello,
    i’ve just create a camera layer, & few 3D shaper layers. TO create a zoom effect i just change the camera position.
    But problem is that, to create zoom effect, i’ve placed three keyframes having values, changing from 2459 to 760 to 757. but between 760 to 757, it does not simply goes from 757 to 758 to 759 & then 760. Instead of this it is changing from 757 to 630 first then changing to 760.
    please help to solve this weird issue.
    Kuljeet Singh replied 10 years, 4 months ago 2 Members · 4 Replies
  • John Cuevas
    April 21, 2016 at 1:55 pm
    Sounds like you have a keyframe interpolation issue. Select all your keyframes, right-click and set to Linear to change this. Also, under preferences there is a place to set the default keyframe interpolation.
    More information:
    FAQ: Why does my layer (camera) move back and forth between keyframes of equal value?
    After Effects Help / Keyframe interpolation
    Online Tutorials
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kuljeet Singh
    April 22, 2016 at 4:32 am
    Thanks Johnny,
    It solved my issue. i’ve changed the interpolation to linear, now everything is fine.
  • John Cuevas
    April 22, 2016 at 1:45 pm
    Glad that fixed it. It would be a good idea to check out some of the videos on interpolation if you are going to be doing a lot of work in AE, it’s a pretty important concept to understand.
    ThinkCK
  • Kuljeet Singh
    April 23, 2016 at 5:05 am
    yes, i’m focusing more on this these days. I’ve also tried Ease & Wizz scripts, which helps alot to create smoother animations.
