Activity Forums Maxon Cinema 4D Keyframes disappear (C4D R19)
  • Keyframes disappear (C4D R19)
    Posted by Alexander Ren on June 15, 2018 at 1:46 am
    when I change an object, and set a keyframes, it works fine. However, if I move it again and create another keyframe, the previous one disappears.
    I just started, but this is really annoying since I can only make pictures instead of actually animating
    I’ll send a video if you really need it
    Alexander Ren replied 8 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    June 15, 2018 at 2:39 pm
    not enough information. You are moving to a different frame before making a new keyframe I assume so a video showing what’s happening would be good.
  • Alexander Ren
    June 18, 2018 at 12:48 am
    I ended up fixing it by adding a visual selector
