Activity Forums Maxon Cinema 4D keyframes
  • keyframes
    Posted by Adam Guy on March 22, 2007 at 5:34 pm
    I have an object that I have keyframed to move about the screen – i want it to pause for a while then continue moving. The problem is that I moved the timeline indicator along the timeline then put in more keyframes – this did the trick. But as i added further movement further down the timeline the keyframes I added to pause the movement had no effect… please help! thanks
    Davesink replied 19 years, 6 months ago 2 Members · 4 Replies
  • Davesink
    March 22, 2007 at 8:35 pm
    You might try duplicating the keyframe where you want the pause to start and moving it to the right in the timeline. Also it might be helpful to familiarize yourself with the f-curve editor. If you flatten out the curve for x,y and z movement where you want the pause to occur, you can avoid having the objects drifting one way or another during the pause. Hope this helps.
  • Adam Guy
    March 23, 2007 at 9:42 am
    Hi, thanks for your help. I know I sound stupid but how do i duplicate keyframes. i have tried hilighting them then copy paste but only one keyframe appears. Cheers
  • Davesink
    March 23, 2007 at 4:56 pm
    To copy a keyframe , just select it in the timline and command/drag to duplicate. Same way you duplicate an object in the Object Manager.
  • Davesink
    March 23, 2007 at 4:57 pm
    Oops make that CONTROL/drag
