Activity Forums Adobe After Effects Keyframes
  • Posted by Michael Williams on November 11, 2010 at 4:32 pm
    Alright so I know that the values between two key frames are determined by After Effects by means of linear/quadratic functions but my problem is that the values between two keyframes that are exactly the same value change. For example the first keyframe is -300 and the second is -300. How do i keep every value the same between these two keyframes without adding keyframes for every frame inbetween.
    Michael Williams replied 15 years, 10 months ago 3 Members · 3 Replies
  • Kevin Camp
    November 11, 2010 at 6:01 pm
    normally you’d just set another keyframe with that same value (or copy/paste the keyframe), however, i think you are experiencing the ‘boomerang’ effect that can happen with non-linear spacial interpolation…. see these tutorials:
    https://library.creativecow.net/search.php?q=boomerang+%22Adobe+After+Effects%22
    for a quick remedy, try selecting the two keyframes and choose animation>keyframe interpolation. set the spacial interpolation to linear.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Eric Chard
    November 11, 2010 at 6:46 pm
    Change the keyframe interpolation to “LINEAR”.
    “Putting the HARM in ‘harmonica’ since 2005.”
  • Michael Williams
    November 12, 2010 at 5:09 am
    Thank you so much. This was exactly what i was looking for, and the tutorial link you provided gave much needed help. Thanks again.
    Sincerely,
    Michael
