Activity Forums Adobe After Effects Expressions Keyframe triggers a fade out
  • Keyframe triggers a fade out
    Posted by Jeff Bobbington on January 14, 2016 at 11:08 am
    Hey all,
    I know this is a simple one but I just cant get it to work.
    Id like to have the opacity to instantly jump up to 100% when an (unrelated) keyframe on a slider is met, then fade out over 20f. If another keyframe happens to interrupt this fadeout then it should still do the same thing, jump up to 100% and fade out. (over and over again). So the resting opacity should be 0% until keyframes are met, sort of like a flashbulb effect when keyframes are met.
    Jeff Bobbington replied 10 years, 8 months ago 2 Members · 5 Replies
  • Dan Ebberts
    January 14, 2016 at 2:50 pm
    This should work:
    fadeTime = framesToTime(20);
    s = effect("Slider Control")("Slider");
    if (s.numKeys > 0){
    n = s.nearestKey(time).index;
    if (time < s.key(n).time) n--;
    if (n > 0)
    linear(time - s.key(n).time,0,fadeTime,100,0)
    else
    0;
    }else
    0
    Dan
  • Jeff Bobbington
    January 14, 2016 at 3:53 pm
    Perfection as usual Dan!
    Greatly appreciated.
  • Jeff Bobbington
    January 15, 2016 at 12:57 pm
    Greatly appreciated!
    How could I go about adding 2 variables to this:
    A delay time – so instead of triggering on the exact frame, it happens a few frames before or after the keyframe is met.
    A fade in duration – so it can take more than 1 frame to go from 0 to 100% opacity.
  • Dan Ebberts
    January 15, 2016 at 5:43 pm
    Maybe like this:
    fadeInTime = framesToTime(5);
    fadeOutTime = framesToTime(15);
    delay = framesToTime(3);
    if (s.numKeys > 0){
    if (n > 0){
    t = time - s.key(n).time - delay;
    if (t < fadeInTime)
    linear(t,0,fadeInTime,0,100)
    else
    linear(t,fadeInTime,fadeInTime+fadeOutTime,100,0);
    }else{
    0;
    }else
    0
    Dan
  • Jeff Bobbington
    January 18, 2016 at 12:40 pm
    Very cool!
    I have found an issue though.
    If I set the delay to a negative number so as to advance the flash effect, it cuts off the fadein effect.
    So a delay of -15 together with a fade of 15 results in the fade being completely cut off!
