Activity Forums VEGAS Pro keyframe to multiple events
  • keyframe to multiple events
    Posted by Stewart Bourke on October 26, 2009 at 3:25 pm
    Going to two in a row today…
    Following from my previous post, I am trying to figure out if it is possible to add keyframes to multiple events at the same time.
    I have a bath of events (each one is a still image) and I would like them all to track-motion across the screen following the same co-ordinates. Is there some way I can apply the same set of keyframe values to multiple events at the same time, or is is a manual job? I have tried grouping, shift, ctrl – all sorts of different combinations…
    I am a VMS 9 user – not pro, and so I guess scripting is out of the question here.
    Many thanks again for such quick follow up on all my posts recently.. I do try and read the docs, and browse the forums before asking these types of questions..
    Stewart Bourke
    Stewart Bourke replied 16 years, 10 months ago 2 Members · 2 Replies
  • Theo Van laar
    October 26, 2009 at 4:51 pm
    Yes, you can do this in VMS. Just make the keyframes in the event pan/crop window of the first picture.
    Close this event pan/crop window and right-click on this event in the timeline. Select COPY.
    Now select one or multiple other events, right-click again and choose PASTE EVENT ATTRIBUTES. All effects, pan/crop keyframes etc will be copied to the selected events.
    Theo
  • Stewart Bourke
    October 26, 2009 at 5:12 pm
    again, thank you. So obvious, I deserve a thump. Worked perfectly.
    Stewart Bourke
