Activity Forums Adobe After Effects keyframe shutter speed?
  • keyframe shutter speed?
    Posted by Laurie Turner on January 28, 2008 at 2:50 pm
    Is it possible to key frame shutter speed. I am using motion blur and there’s one point in the video where I slow down the timing but the blur is too much at this point. So, I want to change the shutter speed at this part only.
    Is this possible?
    I am using AE CS3, with a Mac
    Laurie Turner replied 18 years, 8 months ago 3 Members · 3 Replies
  • Thorsten Miess
    January 28, 2008 at 6:02 pm
    the only way i know is using CC Force Motion Blur instead of the Motion Blur switch. There you can keyframe the shutter angle and so on.
  • Simon Bonner
    January 28, 2008 at 9:23 pm
    I haven’t tried this myself, but perhaps it will work: try making one comp with a high shutter speed, one comp with a low shutter speed, then nest the two comps inside a new comp. Then animate the opacity settings to fade between the two original comps. I don’t know what your project looks like, but maybe if there is a lot of motion blur, this will not be a noticeable switch.
  • Laurie Turner
    January 29, 2008 at 1:40 pm
    I tried using CC motion blur but that isn’t working for me. I think that’s because of Apple Leapord issue.
    I will have to try to put the difference in a different comp like you suggested.
    Thanks for you help =)
