Activity Forums Adobe After Effects Keyframe shortcuts
  • Keyframe shortcuts
    Posted by Bert Beltran on July 12, 2012 at 9:01 pm
    Hello, All
    Im trying to find out if there is a specific keyboard short cut for keyframes. The issue is in order to change a keyframes property you need to have the CTI over the keyframe. If you don’t and you change the property of that layer then it creates a new keyframe where ever your CTI is. That means that you need to then move that new keyframe over to the correct stop and delete the first keyframe that was made.
    I want to be able to change my keyframes property without having to move my CTI over to that keyframe in order to make the change or have to create a new keyframe and then move it over to correct stop.
    Hopefully this makes sense. Thanks in advance.
    Muchos Thank You’s
    Sam Freeman replied 14 years, 2 months ago 4 Members · 3 Replies
  • Walter Soyka
    July 12, 2012 at 9:20 pm
    You can use the J and K keys to move the CTI to the previous and next keyframes visible in the timeline panel, respectively.
    Walter Soyka
  • David Baud
    July 12, 2012 at 11:27 pm
    If you mouse double-click on the keyframe that you want to modify (even if your CTI is not located on top of it), a window will pop up and let you input your new parameters.
    David Baud
    Editor & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
  • Sam Freeman
    July 13, 2012 at 8:08 am
    Or sometimes I add a new keyframe (or copy and paste the one I want to alter) where I am – highlight both – then drag the value for both at the same time. Delete the new keyframe.
    Sounds like it would take a lot of time, but it doesn’t really.
