Activity Forums VEGAS Pro Keyframe Problem
  • Keyframe Problem
    Posted by Brian Tallant on January 16, 2013 at 12:15 am
    I did a bunch of keyframing on the second half of a clip and now I want to trim off the first half of the clip. However, every time I try, the keyframes are now no longer placed where I originally had them – they don’t seem to want to move with the clip. What do I do?
    Roger Bansemer replied 13 years, 7 months ago 4 Members · 3 Replies
  • Stephen Mann
    January 16, 2013 at 3:44 am
    First – everything on the timeline is an event – not a clip.
    What are you trying to do, because you can’t “keyframe” an event (or clip), you keyframe effects, mostly.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Tyson Onaga
    January 16, 2013 at 6:15 am
    If you mean … you added P/C keyframes to an event and you want to “trim” the front, then:
    a. find the “trim” point on the Vegas timeline
    b. select the event
    c. “s” (to split event)
    The keyframes in the second event should be correctly adjusted to time[0] on that event’s P/C timeline.
  • Roger Bansemer
    January 16, 2013 at 12:28 pm
    I may be understanding your question a bit differently. Here’s my explanation.
