Activity › Forums › Adobe After Effects › keyframe problem
  • keyframe problem
    Posted by Stig Olsen on August 8, 2013 at 8:54 am
    I have some elements that is supposed to move over the screen with a white background.
    I have key framed the elements to move over the screen in different speed but somehow I see some “chopping” or what you call it. The movement is not as smooth as is should be. The keyframes are set to ease ease.
    Stig
    Dustin Lawhorn replied 13 years, 1 month ago 2 Members · 3 Replies
  • Dustin Lawhorn
    August 8, 2013 at 2:01 pm
    Stig,
    Just for clarification, are you seeing this problem on the Rendered file (final file) or during the RAM Preview or just in the Comp viewer?
    -dl
  • Stig Olsen
    August 8, 2013 at 2:12 pm
    Hi, both in the composer window, the monitor and the rendered output.
    It is also some jittering / stuttering on the objects that move horisontally.
    Stig
  • Dustin Lawhorn
    August 8, 2013 at 4:33 pm
    Hmmm. It could be jutter? check out the thread here: https://forums.creativecow.net/thread/2/963872
    -dl
