Activity Forums Adobe After Effects Expressions Keyframe Overshoot with no oscillation
  • Keyframe Overshoot with no oscillation
    Posted by Andres Torres on September 16, 2012 at 8:49 pm
    I’d like to create an expression similar to your Keyframe Overshoot example except I’d like the object to overshoot the position and ease into a stop with no oscillation. Possible variables could be mass and friction to control the ease to stop motion.
    Thanks.
    freq = 3;
    decay = 5;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time) n--;
    if (n > 0){
    t = time - key(n).time;
    amp = velocityAtTime(key(n).time - .001);
    w = freq*Math.PI*2;
    value + amp*Math.sin((t)*w)/Math.exp(decay*(t))/w;
    }else
    value
    Dan Ebberts replied 13 years, 11 months ago 2 Members · 3 Replies
  • Dan Ebberts
    September 16, 2012 at 9:27 pm
    You should be able to get rid of the oscillation by bumping up the damping (decay). Try freq = 1 and decay = 15 and see if that gets you closer.
    Dan
  • Andres Torres
    September 16, 2012 at 10:16 pm
    I keep getting this error with the expression when I change the freq and decay values.
    invalid numeric result (divide by zero?)
    Error occuredat line 13
    Property: ‘Position’
    I tried your suggested values and the position always returns to the last keyframed value. I’m looking to go past the keyframe and ease to a stop based on velocity and a friction variable.
    Thanks.
  • Dan Ebberts
    September 16, 2012 at 10:23 pm
    It would help if you would paste in the expression that’s generating the error.
    Dan
