Activity Forums Adobe After Effects keyframe issues
  • keyframe issues
    Posted by Chaddix Malchow on October 23, 2011 at 5:21 am
    hi all,
    So im working on a title right now, wanting to make it stay stagnent, i cant get a good track so im going through and manually doing it(its only like 3 seconds) but when i set 2 position keyframes, both with same x-axis cordinates, and only the Y is changing. So when i scrub between the 2 keyframes, the x (the one that should be not changing its parameters) changes its parameters, first it goes up a few, stays that way, then goes back down to what it was starting. so its acting like theres 4 keyframes, when theres only 2. im really confused and frustrated with the occuring issue.
    any help would make my life much easier
    win 7 64bit/adobe cs5
    2x xeon quad cores
    12gb memory
    5tb Storage
    Nvidea GTX 570
    Roland R. kahlenberg replied 14 years, 10 months ago 3 Members · 2 Replies
  • Todd Kopriva
    October 23, 2011 at 5:31 am
    Change the spatial interpolation to linear.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Roland R. kahlenberg
    October 23, 2011 at 7:58 am
    Look at using the menu item, Animation>Separate Dimensions and/or using a Hold Keyframe. Changing Spatial KFs to linear will inevitably delimit the shape of your path and it should be the last thing you do. Additionally, even if you do so, ensure that you do so correctly, within the correct View Pane.
    Oftentimes, with 3D layers, such issues, if cannot be corrected with Separate Dimensions and/or Hold KFs then the Spatial KF in only ONE of View Panes need to be linearized.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia.
