Activity Forums Adobe After Effects Keyframe issue
  • Keyframe issue
    Posted by Walkingduck on May 6, 2005 at 7:35 am
    Hello folks,
    this is probably a basic question and I don’t remember how I fixed it before.
    ok, I set the keyframes in position from left to right, and add another key to move further right.
    Basically, what’s happing is, the second keyframe changes into weird bezier type, so that the object will move back to left a little and then move to right. I wonder if there’s a way I can avoid this issue without adjusting the bezier all the time. I had to move the bezier in the comp.
    Can I get some help or tips for this?
    Walkingduck replied 21 years, 4 months ago 2 Members · 2 Replies
  • Visual_guy
    May 6, 2005 at 3:06 pm
    James –
    Annoying isn’t it? The easiest way around this is to select all the keyframes,
    then under the animation menu select “keyframe interpolation” and change
    “spatial interpolation” to “linear”. That should take care of it.
    Brett
  • Walkingduck
    May 8, 2005 at 7:18 am
    thanks a lot.
