Activity Forums VEGAS Pro Keyframe interpolation
  • Keyframe interpolation
    Posted by Nick Mcmahon on February 26, 2015 at 1:27 pm
    Been trying to learn how the keyframe interpolation works in relation to the ‘English’ single word expressions.
    That is fairly straightforward but then we can also adjust the amount from 0-100% and I’m about to run a test to visually see if there is any difference by rendering out the same stills sequence using ‘smooth’ interpolation at 0% and again at 100% for comparison.
    Is it correct that only the first keyframe needs to be selected as ‘smooth’ and it will then run that interpolation at what ever % amount is chosen until the next keyframe…?
    My stills sequence is sync’d to the music track so each still changes on the back beat (don’t know the correct musical expression for that in beats terminology)… each still has a zoom either in or out and I’m attempting to find the best looking result when it plays in my rendered project so it flows visually at it’s best.
    Nick… BASE1268
    3…2…1…C ya
    Nick Mcmahon replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
