Activity Forums VEGAS Pro Keyframe Frustrations
  • Keyframe Frustrations
    Posted by Mark Pi on September 6, 2007 at 3:05 am
    I’m trying to loop a pan/crop animation of a still for a looping background, but Vegas’ keyframe interpolation is destroying the effect by slowly starting into the animation then speeding up — the result is that at the end when it loops back to the beginning there’s a large jump in the apparent animation speed. Not pretty.
    Both keyframes at beginning and end are “linear”, and the “smoothness” is set to 0 for both. It should run through at only one speed, right?
    Any ideas?
    Charles Avanti replied 18 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Douglas Spotted eagle
    September 6, 2007 at 3:07 am
    you SURE they’re both set to 0 and linear? You’re describing a non-linear action
  • Mark Pi
    September 6, 2007 at 6:34 am
    Positive. I checked that a billion times. I also checked to make sure there wasn’t another keyframe hidden nearby.
  • Charles Avanti
    September 6, 2007 at 4:05 pm
    Your not by chance viewing a previously rendered version on a new track above, are you?
    Charlie
  • Mark Pi
    September 7, 2007 at 12:42 am
    No, there’s only the one video (a single picture, really) on one track.
    Thinking it’s a bug in Vegas (which I surely would have run into before), I tried to put some video in front of it and behind it, then tracks above and below, but the behaviour is restricted to the single clip.
    I spent a couple hours yesterday trying different things to sort it out, but nothing… Argh!
    Could it be that I’m doing two different things within a keyframe — a rotate, and a zoom at once?
    September 7, 2007 at 1:52 am
    Not likely. If you can control the attribute, the keyframe can recall it.
    Maybe you have a track muted/solo’d?
    Maybe you have FX turned off in the preview window?
  • Charles Avanti
    September 7, 2007 at 2:09 pm
    Try making a totaly new project with just this event.
    Charlie
  • Mark Pi
    September 9, 2007 at 1:35 pm
    Tried that. The project I’m working with now is just the one single frame and two keyframes.
  • Charles Avanti
    September 9, 2007 at 8:36 pm
    Try 30 frames. 1 second of video.
    Charlie
