Activity Forums VEGAS Pro Keyframe Button not available in the Text Window?
  • Keyframe Button not available in the Text Window?
    Posted by Rafi Bagramian on November 30, 2006 at 11:05 pm
    Why is my Keyframe Button not available in the Text Window?
    If I lay down Keyframes they do work, but I can
    Edward Troxel replied 19 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafi Bagramian
    December 1, 2006 at 12:04 am
    I should clarify! If I add an FX the Keyframe works. But if I try to work with the Text Properties (Tracking/Scaling/Color) then the Keyframe button if off!!
  • Edward Troxel
    December 1, 2006 at 2:31 pm
    Do you mean the “Sync Cursor” button? If yes, that doesn’t work on generated media. Otherwise, what do you mean by the “keyframe button”?
    Edward Troxel
    JETDV Scripts
  • Rafi Bagramian
    December 1, 2006 at 6:04 pm
    Yes, sorry I do mean the Sync Cursor button.
    I wonder why it
  • Edward Troxel
    December 1, 2006 at 9:27 pm
    The best way to change color over time would be to use the text as a mask and put the changing color on a track below it. To change sizes, make the text the LARGEST you want it to be and use Pan/Crop to reduce its size as needed.
    Edward Troxel
    JETDV Scripts
  • Rafi Bagramian
    December 2, 2006 at 7:50 am
    Okay, Thanks.
  • Terje A. bergesen
    December 7, 2006 at 12:01 pm
    Just for the record, the (or at least my) generated media box, when working with text, has a key-framer at the bottom. I can change text size, color and font during the duration of the text event. Font size etc changes are instant from one key-frame to the next (it jumps from 72 to 16 on the key frame) but color changes are gradual.
    Terje A. Bergesen
  • Edward Troxel
    December 7, 2006 at 2:22 pm
    Yes, all generated media has a timeline along the bottom allowing the creation of keyframes. He was actually talking about the “Sync Media” button which is grayed out on all generated media.
    Edward Troxel
    JETDV Scripts
