Activity Forums Adobe Premiere Pro Keyframe animation not smooth in PP5.5
  • Keyframe animation not smooth in PP5.5
    Posted by Benjamin Ausmith on June 7, 2012 at 7:06 pm
    Hi everyone. I just did an H.264 export of some footage, involving a still image that I panned using position keyframing. On close inspection, the movement isn’t as smooth as I would expect. It moves smooth for 3 frames, then jumps a little on the 4th frame. I went back to my timeline and noticed that isn’t not the fault of the codec– the jump is actually in the timeline itself. I verified this by doing an export in Photo-JPEG– same problem.
    So what’s the deal? If I have only two position keyframes, why would Premiere not interpolate it smoothly? And for the record, everything is in 29.97 fps– not that it particularly matters when I’m just panning a still.
    Any thoughts?
    Benjamin Ausmith
    Post-Production Assistant
    Monadnock Media, inc.
    Benjamin Ausmith replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
