Activity Forums Apple Final Cut Pro Legacy Keyframe a transition
  • Keyframe a transition
    Posted by Sean Connelly on April 6, 2011 at 4:20 am
    Is there a way to use keyframes on a transition? Basically, I have a scene set up so that a circle wipe appears behind a person who I have edited out of the shot frame by frame (creating a layer with just the person and the original unedited layer behind them, with the circle wipe that I created with several color mattes between the original layer and the character layer) I want to set up an actual circle wipe transition so that the original bottom layer appears to be “erased” by the layer of color mattes to reveal the next scene.
    OR does anyone have any suggestions on how to do this another way?
    Sean
    Cody Walters replied 15 years, 4 months ago 2 Members · 1 Reply
  • Cody Walters
    April 6, 2011 at 3:14 pm
    You could use the effect mask shape, create your circle for the background and keyframe that for your transition…just a thought.
    Cody Walters
    Mac Pro 2.26GHz 8 Core
    16 GB 1066 MHz DDR3
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
    https://www.codywaltersvideo.com
