Activity › Forums › Adobe After Effects › Keyed Clip flashes and I don’t know why?
  • Keyed Clip flashes and I don’t know why?
    Posted by Tyler M. on July 10, 2009 at 3:58 pm
    I’ve keyed out my subjects but after I export them out of After Effects they have some sort of contrast flash. Just my subject’s black levels change a little bit brighter. I checked the source footage and everything is good. I play it in AE but it doesn’t happen. However, there is a flash in the video but nothing changes. Any ideas?
    Tyler M. replied 17 years, 2 months ago 3 Members · 3 Replies
  • Jim Dodson
    July 10, 2009 at 6:15 pm
    Were you using multi-processor rendering?
    I’ve had the same problem when “render multiple frames simultaneously” was checked “on” in AE preferences…
    Jim Dodson
    8 Core Intel — Mac – OSX
  • David Bogie
    July 12, 2009 at 2:15 pm
    Do these flashes occur at the exact same frames each time you render? If so, it’s your media. If not, it’s still your media, likel;y. What format is the source media? I’m guessing it is HDV.
    bogiesan
  • Tyler M.
    July 12, 2009 at 9:26 pm
    Yes, it is HDV and it does occur at the same time but I checked the source footage and there is no flash. Only when I bring it into AE does the flash occur. Is it the HDV codec and AE that causes this?
