Activity › Forums › Adobe After Effects › Keyboard shortcuts where there aren’t any?
Posted by Jerry Sneede on May 27, 2011 at 2:21 pmAnyone know if it’s possible to create a keyboard shortcut in AE where one doesn’t already exist? I’d especially like to make some in the Scripts pulldown menu.
Cassius Marques replied 15 years, 4 months ago 3 Members · 4 Replies -
Cassius Marques
May 27, 2011 at 2:29 pmFor the scripts, under General… you can assign shortcuts to “run script number #”. Other than that. I don’t think you can add a shortcut when there is none.
I sometime ago wanted to add a shortcut to the “invert keyframes” command. The way I could get it to work was a script that executed that command and adding a shortcut to it. All you got to do is rename your scripts accordingly so they won’t change hierarchy when you add more to the scripts folder.
Jerry Sneede
May 27, 2011 at 2:41 pmHow do you assign shortcuts to run script #? What do you mean under General?
Walter Soyka
May 27, 2011 at 3:11 pmThere are also a couple scripts that might help: Keyed Up and Launch Pad.
https://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&extid=1698043
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Cassius Marques
May 27, 2011 at 5:09 pmMy bad. I meant using KeyEd Up script, I thought you were referring to it from the beginning
