Activity Forums Adobe After Effects Keyboard shortcuts: Change comp duration to layer’s? Move to end of layer?
  • Keyboard shortcuts: Change comp duration to layer’s? Move to end of layer?
    Posted by Marc Brown on June 26, 2008 at 8:34 am
    I’m finalizing a project at this time, and the process involves selecting small clips from dozens of large ones, painstakingly ensuring they start/end on exact frames, and storing the results of each edit as its own comp. The mass of individual comps (clips) will ultimately be assembled into a chronology.
    The biggest timesinks in this process right now are: 1) Determining the exact duration (minutes, seconds, frames) of each clip after it’s been whittled to size. 2) Changing the comp duration to the layer’s duration, so that when I import the comp into the final assembly, it won’t include several minutes of missing video (black).
    Keyboard shortcuts for those functions would be great. Particularly a shortcut for changing a comp’s duration to that of the selected layer. Either a shortcut or a right-click solution. Obviously, the system I have now – where I move the cursor around until I stumble upon the end of the clip, note the frame number, open the composition settings, and type in the number I memorized – is tedious and slow. I’ve got literally hundreds of edits.
    I’ve looked around, but haven’t had immediate success with this. Anyone have a suggestion? ;p
    Peter Van der zee replied 18 years, 2 months ago 3 Members · 2 Replies
  • Jan Sherlink
    June 26, 2008 at 9:09 am
    Select your layer in the timeline,
    press CTRL+ALT+B
    this will adjust you work area to your selected layer
    Right Click your work-area
    select “Trim Comp to Work Area”
    done.
    this is the fastest method I know
    cya,
    Jan
  • Peter Van der zee
    June 27, 2008 at 2:32 pm
    wow, that’s good “alt-apple-b” in my case
    I always navigate to layer in point “i” start workarea “b”
    goto outpoint “o” end of workarea “n” menu “trim comp to workarea”
    but yours is faster!
    http://www.zeemotion.com
