Activity Forums DaVinci Resolve Keyboard Shortcuts
  • Keyboard Shortcuts
    Posted by Adam Berch on February 7, 2026 at 12:23 am
    Hi, I am having real problems with keyboard shortcuts. I am trying to make the letter S a shortcut for the Selection Mode tool. That letter is already assigned a shortcut. What is the process for deleting the shortcut that is already on there and assigning the Selection Mode tool to it?
    I have sent a picture showing you the shortcut on the letter S now. I want the Selection Mode tool on there instead.
    Thanks in advance
    Adam
    Ivan Eldredge replied 7 months, 1 week ago 2 Members · 1 Reply
  • Ivan Eldredge
    February 7, 2026 at 3:57 am
    Hello Adam!
    In the Keyboard Customization window, the first thing you should do is use the command search on the right-hand column of the panel. Search for the command that currently has the S key assigned. In most default layouts it’s usually Toggle Slip / Slide Mode (wording can vary slightly by version).
    Once you find it, click that command. You’ll see its assigned shortcut next to it, and right beside the S binding there should be a small X. Click that X to remove the shortcut and free up the S key.
    After you’ve cleared it, then you can search for the command you actually want, click it, and assign S right there in the same command list.
    Good luck with your project!
    Best,
    Ivan Eldredge
