Activity Forums Adobe InDesign Keyboard Shortcut to scroll through open Projects/Layouts
  • Keyboard Shortcut to scroll through open Projects/Layouts
    Posted by Sean Lloyd on April 19, 2023 at 12:05 am
    Hello Creative Cowers,
    I am in the process of editing a contents section of my book, which requires going through the book and making sure the page numbers are correct. I made a copy of the document so I wouldn’t have to keep scrolling up and down through the whole document to save time, but now I’m wondering if there is also a shortcut so I can more quickly move from one document to the other. Sure I can just click on them at the top of the screen, but this is going to be a ton of work, so every second adds up. I’ve looked in a couple of In Design keyboard shortcut posts online, but haven’t found anything, yet.
    Any help would be much appreciated. Thanks…
    Sean Lloyd replied 3 years, 4 months ago 1 Member · 1 Reply
  • Sean Lloyd
    April 25, 2023 at 11:21 pm
    Hi All,
    Quickly Switch Between Open Tabbed Documents. This is the phrase I should have looked for, and the answer is command/tilda.
    Just in case someone else is having the same issue.
    Cheers…
