Activity › Forums › Adobe Premiere Pro › Keyboard shortcut to quickly zoom into audio waveform in source panel
  • Keyboard shortcut to quickly zoom into audio waveform in source panel
    Posted by Steve Cornell on July 30, 2012 at 5:11 pm
    In FCP, keyboard mapping zoom in/out allows you to quickly zoom into audio waveforms in the source window. I mapped zoom on PP 5.5 and while this works in the timeline ,it doesn’t work in the source panel. Zooming in by mouse is just to time intensive and exhausting.
    If anyone knows how to create a keyboard shortcut for this, please let me know.
    thanks!
    Kevin Monahan replied 14 years, 2 months ago 3 Members · 5 Replies
  • Kevin Monahan
    July 30, 2012 at 6:02 pm
    Tap the + key a couple of times. Work for you?
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Mark Brown
    July 31, 2012 at 7:50 am
    I have become fond of Command + G. This opens a small dialog to type in a new gain level which can be plus or minus dB. First select an audio clip in the timeline.
    Kuhnen
    Mark Brown
    InterMountain Digital
    MacPro quad. Premiere Pro CS6
    Matrox mini MAX. Former FCP7 editor.
  • Steve Cornell
    July 31, 2012 at 3:05 pm
    No, didn’t work. I tried ‘shift’ + as well. Anyway to map a keyboard shortcut to this ?
    Also, if I double click a clip from my sequence timeline and load it into the Source panel, zooming out reveals much more than the wave form I’ve already cut. Its showing me the entire waveform from the entire original clip I imported into to the project. At this point, I’ve made my cuts and only want to see from the in to the out point and nothing more. Anyway to do this ?
    thanks.
  • Steve Cornell
    July 31, 2012 at 3:10 pm
    Thanks Mark. I mapped Cmd+G to gain. That’s a time saver.
  • Kevin Monahan
    July 31, 2012 at 9:39 pm
    [Steve Cornell] “No, didn’t work. I tried ‘shift’ + as well. Anyway to map a keyboard shortcut to this ? “
    Sorry, the +/- buttons work on waveforms in Premiere Pro CS6, and not in CS5.5. There is the zoom bar, but probably not what you’re looking for.
    [Steve Cornell] “Also, if I double click a clip from my sequence timeline and load it into the Source panel, zooming out reveals much more than the wave form I’ve already cut. Its showing me the entire waveform from the entire original clip I imported into to the project. At this point, I’ve made my cuts and only want to see from the in to the out point and nothing more. Anyway to do this ? “
    The area you marked should be highlighted. You can use the zoom bar to zoom in closer.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
