Activity Forums Adobe Premiere Pro Keyboard shortcut to add keyframe
  • Keyboard shortcut to add keyframe
    Posted by Perry Cheng on May 26, 2005 at 10:49 pm
    I have tried to search for keyboard shortcut to add a keyframe in PPro Keyboard mapping tool… but no luck. Am I missing something?
    Perry
    Perry Cheng replied 11 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Perry Cheng
    May 27, 2005 at 12:26 am
    I forgot to mention:
    Just got Pro 1.5 and it seemed not as threatening as I imagined. It actually had a lot common with 6.5, with a few changes I need to get used to. For one, I don’t know if this can be customized… if I move a clip to another clip, it shorten the previous clip, overlaying… What if I just want it to joint previous clip? Also, is there a keyboard shortcut for Adding a keyframe without pushing the Add keyframe icon? (I got a contour device)
    Thanks again all for you input in the past few weeks.
    Sincerely,
    Perry
  • Mike Velte
    May 27, 2005 at 3:49 pm
    Hi Perry,
    Keyframes are added automatically with any value change (with Toggle Animation turned on). I dont think there is a short cut to add a “same value” keyframe without using the Add Keyframe button.
    Maybe dont understand your question about joining clips….just butt them together?
    https://www.video2stream.com
  • Perry Cheng
    May 27, 2005 at 3:58 pm
    Mike,
    First of all, thanks for your help.
    “Keyframes are added automatically with any value change (with Toggle Animation turned on). I dont think there is a short cut to add a “same value” keyframe without using the Add Keyframe button.”
    What I wanted to build a shortcut key in which when I have my timeline over a certain point, I don’t want to have to move my mouse to click on Add/Remove keyframe dot. I would like to be able to just hit a key on my Contour Device to add a keyframe right there on the time line. I think this will be faster for me.
    “Maybe dont understand your question about joining clips….just butt them together?”
    When I have a Clip1 on timeline, and want to drag another Clip (Clip2) adjacent to it, I have to move very carefully not to overlay on any portion of Clip1, otherwise Clip1 will be splitted into 2 clips (i.e. Clip1a-Clip2-Clip1b) In 6.5, I don’t have to worry about this, I can simply place Clip2 near the end of Clip1 and it will be placed butt-to-butt.
    Thanks again Mike.
    Sincerely,
    Perry
  • Steven L. gotz
    May 28, 2005 at 2:47 am
    If I might be permitted to butt in here…
    If you change the value, a keyframe is created. Assuming that the stopwatch has been clicked, of course. There is no need to add a keyframe that way.
    On the other hand, I put in a feature request (please do the same) to have a way to set all of the beginning keyframes to the current value. In other words, hit the stopwatch and set a keyframe with one keystroke.
    To join clips easily, you can use ripple delete, or, you just need to make sure that “Snap” is turned on. Then you will see a verticle line show up to let you know where you are. Snap has an icon on the timeline window just under the Sequence number and timecode. Looks like a magnet.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Wolf Lawrence
    November 10, 2014 at 9:24 pm
    what is the stopwatch feature? maybe they took it out in last 9 years.
    right now i’m having the same exact user question 9 years later related to this thread and this one from 2013: “still no keyboard shortcuts for scale/position keyframes in Premiere Pro CC?” https://www.dvxuser.com/V6/archive/index.php/t-311881.html
    i’m finding a lot of basic features you’d think are core to any project are requested by many users of adobe but not addressed with an upgrade even 9 years later. perhaps this feature request is different.
  • Wolf Lawrence
    November 10, 2014 at 9:27 pm
    wait, found a possible answer on another page: alt+shift+P to place a keyframe on the timeline. i’ll try it.
  • Wolf Lawrence
    November 10, 2014 at 9:30 pm
    i find a lot of basic features core to any project result end up as feature requests but not addressed with an upgrade even 9 years later. perhaps this feature request is different. AE has it.
  • Perry Cheng
    November 12, 2014 at 2:53 am
    Lawrence, I moved on. Life is too short waiting for Adobe to fix these features. I adapt and get used to it. Oh well… Best wish.
    Perry
