Activity Forums Adobe After Effects keyboard shortcut to add keyframe with time remapping
  • keyboard shortcut to add keyframe with time remapping
    Posted by Stan Heard on September 21, 2009 at 9:11 pm
    Hi, is there a keyboard shortcut to add a keyframe after enabling Time Remapping? I know there is a “Toggle Hold Keyframe”, but it doesn’t add a keyframe, it simply changes the keyframes you’ve already made. I’d like a keyboard shortcut so that I can quickly scrub through footage to create stop action clips. Thanks!
    Dan Fredley replied 14 years, 2 months ago 2 Members · 2 Replies
  • Stan Heard
    September 22, 2009 at 2:53 pm
    Hi Dave,
    I saw this keyboard shortcut page before. I did try to click “Option+shift+RR”, but it simply defaults to Rotation. Is there a keyboard shortcut to add keyframes once you’re in Time Remapping, so that I can later change them to Toggle Hold Keyframe? If I use the Toggle Hold Keyframe keyboard shortcut, it simply converts the first Time Remapping keyframe at the beginning of the comp into a toggle hold keyframe. It does not ADD a Toggle Hold Keyframe at any other point, such as 30 frames into the comp. Thanks, sorry for the bother,
    Stan
  • Dan Fredley
    June 1, 2012 at 9:10 pm
    I know this thread is old, but for any future time-remap keyboard shortcut seekers:
    https://f1.creativecow.net/4231/timeremapper-script
    Dan Fredley
