Activity Forums Apple Final Cut Pro Legacy Keyboard Shortcut – Selecting a clip in timeline?
  • Keyboard Shortcut – Selecting a clip in timeline?
    Posted by Rob Grauert on August 7, 2010 at 11:05 pm
    Is there a keyboard shortcut for selecting a clip in the timeline if you don’t already have one selected? And possibly changing which clip is selected after one is already selected; like using the arrow keys or something?
    This would be great. I feel like it’s the only thing that keeps me using the mouse
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
    John Fishback replied 12 years, 9 months ago 6 Members · 10 Replies
  • 10 Replies
  • John Fishback
    August 8, 2010 at 7:28 pm
    I’m not in front of my machine at the moment, but believe the : and ” keys will jump the playhead forward (“) or backward (:) to the start or end of the next/prior clip.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24” TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Rob Grauert
    August 8, 2010 at 8:25 pm
    yes, you’re right. That’s not what I’m looking for though. I want to actually be able to select a clip so I can use the < and > keys to move clips around.
    Thank though
    Rob Grauert, Jr.
  • John Fishback
    August 8, 2010 at 8:45 pm
    There’s the shuffle or swap edit, but you still need the mouse. I don’t know of a way to select a clip and then use a keyboard command to move it in the timeline.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
  • Rob Grauert
    August 8, 2010 at 9:26 pm
    hmm…oh well. It’s not THAT big of a deal. Thanks anyway
    Rob Grauert, Jr.
  • Kevin Monahan
    August 9, 2010 at 8:32 pm
    Make sure your the track is auto selected for your clip first. Type X to “Mark Clip” then type Control – A to select between in and out.
    Bingo: your clip is selected using shortcuts. Sorry there isn’t a single key for this.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
    Follow Me on Twitter!
  • Rob Grauert
    August 9, 2010 at 9:04 pm
    not bad at all!
    I almost always have my clips on V1 anyway, so all I have to do is use J or L to move the playhead over the clip. Then press X. Then Option A to select the clip (Control A was marking In and Out around my whole timeline)
    Thanks! Anyone want a free mouse? hahah
    Rob Grauert, Jr.
  • John Dobrich
    September 9, 2010 at 11:02 pm
    It is more than a couple of keyboard clicks, but to me, it’s easier than reaching for the mouse to click on a clip in the time line.
    For syncing dailies, I have all the clips laid out one after another in the timeline.
    1. Starting on first clip click X – marks in and out, Option-A – selects that one clip, Option-X – removes in and out marks.
    2. I find the slate clap and hit M – adds a marker to clip.
    3. Hit down arrow – goes to next clip
    Repeat and rinse 😉
    Once clip is selected, you can also move it around with the arrow keys while holding down the Option key.
    It works for me – once I got into a rhythm.
  • Stasiu Sosinski
    June 24, 2012 at 12:05 am
    Use “V” to select the edit point and then “U”to select the desired clip. There are two methods to work with the sub clip: use “F” if you want the original source clip, use “Enter” if you want a sub clip that has already been manipulated. This opens the clip in the Viewer Window.
    V – Selects Nearest Edit Point
    U – Toggles which side of the edit you want to select
    F – References the source clip
  • Guillaume Monette
    December 16, 2013 at 6:47 pm
    Hey, i’m like almost 4 years too late but still it’s fun to have an answer no?
    I found something today. I had to manually bypass a filter in each clip of my 30min show. First thing I thought was that I need to double click a clip, then hit bypass, then double click next clip, them bypas etc….
    But then I noticed that once you double click your first clip, it goes in the viewer and you have the option then to use the up and down arrows to move from clips to clips but each clip comes automatically loaded in the viewer, ready for what ever you wanna do with it.
    I’m not too good in english but I hope it makes sense
    G
  • John Fishback
    December 16, 2013 at 7:22 pm
    Another thought is to change the first clip the way you want it, then Copy it, select the rest of the clips, then Paste Attributes to change all the clips at once.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
