Activity Forums Apple Final Cut Pro Legacy keyboard shortcut not working
  • keyboard shortcut not working
    Posted by Tracey Dunn on December 22, 2007 at 12:12 am
    The command x keyboard shortcut won’t work.
    I know the keys work because command s works and holding down just the x key gives me a clip highlight and in and out points. Also, highlighting the clip and hitting command x deletes the clip….and the key types an “x”
    I have tried resetting the default keyboard settings, closing down and restarting, also rebooting.
    It doesn’t look like this is assigned to anything else on the OSX system.
    I have even tried assigning it thru the apple/system preferences/keyboard & mouse/keyboard shortcuts + drop down FCP etc.
    Any suggestions, greatly appreciated.
    I’m sure I’m just missing something
    T.
    Tracey Dunn replied 18 years, 8 months ago 2 Members · 2 Replies
  • Bret Williams
    December 22, 2007 at 2:56 am
    What exactly did you expect cmd+x to do? All it does is cut. In other words, if you have a clip highlighted, it deletes it, as you said.
  • Tracey Dunn
    December 22, 2007 at 3:13 pm
    It won’t cut!
