Activity Forums Apple Final Cut Pro Legacy Keyboard shortcut for Trim Edit window
  • Keyboard shortcut for Trim Edit window
    Posted by Stephen Lovett on May 3, 2009 at 10:09 pm
    Hi all,
    I know there has got to be an easier way than going to the mouse 🙂
    I’m cutting from long continuous takes. I can set in and out points, subclip, name the clip, set focus to the timeline, F10, hit the up arrow key, and I’ve got my rough edit into place.
    I can play around the edit, \, but I usually need to tweak a few frames.
    I haven’t found a keyboard short cut or other method for pulling up the trim edit window.
    I’m a big fan of the mouse for a lot of things… editing isn’t really one of them 😉
    Your suggestions are most welcome.
    Thank you all in advance,
    Steve
    Xavier Paredes replied 14 years, 2 months ago 3 Members · 3 Replies
  • Captain Mench
    May 4, 2009 at 1:39 pm
    Command-7 opens up the trim edit window once you have a single edit selected.
    Check the manual on using dynamic editing in the trim window.
    Cycling thru U changes the shape/side of the edit. You can use the number keyboard to trim.
    Does that help a little?
    CaptM
  • Stephen Lovett
    May 4, 2009 at 6:41 pm
    Michael,
    Thank you, Thank you, Thank you!
    It helps more than a little.
    Not reaching for the mouse to bring up that window will save me hours and hours.
    We’re in the middle of a remodel, so its going to take some digging to find the manuals. I left Lisa Brenneis’s book out, but this time she failed me. (An unusual occurrence, her guide and Larry Jordan are my go to guys)
    Michael to the rescue. 😉
    All the best, and thanks again,
    Steve
  • Xavier Paredes
    July 17, 2012 at 12:15 am
    Ok so command+7 opens the ‘Trim Edit’ window; Is there a keyboard shortcut to close it? I’ve got more than 500 clips to edit so I’m trying to automate things. Mousing around ain’t gonna cut it. No pun!
    Xavier
