Activity › Forums › Apple Final Cut Pro › Keyboard shortcut for set all ‘Transform’ keyframes?
Posted by Brian Thomas on September 10, 2017 at 4:49 pmI looked in the Help file but couldn’t find it.
Many thanks in advance, Brian.
FCPX and PPro 6. iMac 24 + MBP 15″. Near Geneva, Switzerland
Brian Thomas replied 9 years ago 2 Members · 4 Replies -
Robin S. kurz
September 11, 2017 at 12:13 pmSimply hit ⇧T and the keyframe button at the top left of the viewer?
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Brian Thomas
September 11, 2017 at 12:30 pmThanks Robin but what I’m trying to avoid is constantly moving the mouse up to a relatively small target being the little keyframe icon between the keyframe navigational buttons.
The thing is, as I edit I usually have transform ‘on’ as I’m frequently changing ‘Position’ and ‘Scale’ – I do a lot of multicam singing and dancing stuff and most of my camcorders are static. It would be great to be able to click on a clip and use a keyboard shortcut to get all Transform keyframes set exactly where I am at that point.
So, any ideas….?
Robin S. kurz
September 11, 2017 at 12:46 pmThe only way you’ll be able to do that (that I know of) is have the Videoanimation-Editor (⌃V) open for the clip, select the Transformation bar and hit ⌥K when you need it…
– RK
Brian Thomas
September 11, 2017 at 1:13 pmAgain, thanks Robin, certainly an approach but not as easy as I’d hoped. I’ll put an enhancement request in but I won’t hold my breath in anticipation of it being implemented…
