Activity › Forums › Creative Community Conversations › Keyboard shortcut for selecting clips outside primary
Posted by Stephen N. on July 25, 2013 at 4:03 pmI know “C” is the shortcut to select a clip. Anyone know the keyboard shortcut to select the clip thats above or below the primary storyline?
thanks
Ronny Courtens replied 13 years, 2 months ago 5 Members · 11 Replies -
Andy Neil
July 25, 2013 at 5:02 pmThere isn’t one. You need to hover with the cursor and use C or X. Send feedback to apple via the Final Cut Pro menu. it’s something we should definitely have, even if it’s just using the arrow keys to jump the “select” box to another clip.
Andy
https://www.timesavertutorials.com
Stephen N.
July 25, 2013 at 5:08 pmBummer. I also notice there is no keyboard shortcut to nudge clips by frame inside the the viewer.
Andy Neil
July 25, 2013 at 5:12 pm[Stephen Nahroniak] “I also notice there is no keyboard shortcut to nudge clips by frame inside the the viewer.”
Not sure what you mean by this. You can nudge clips frame by frame by selecting them in the event browser and using the left and right arrow keys to advance one frame forward or backward in the clip.
The viewer itself doesn’t have a scrubber, but that’s just the way the program works. You scrub the filmstrip in the event browser to view the video in the viewer.
Maybe I just don’t understand what specifically you’re trying to do in X.
Andy
Ronny Courtens
July 25, 2013 at 5:18 pmIf you mean nudging in the Timeline:
Nudge 1 frame to the left: ,
Nudge 1 frame to the right: :
This is on a French keyboard.
Stephen N.
July 25, 2013 at 5:18 pmSorry if I wasn’t clear.
In 7 you could move a particular element that was in the canvas pixel by pixel by selecting it in the canvas and use the option+left arrow keys. It makes it more precise than using the mouse to move elements in the canvas sometimes. I haven’t found that you can do that in X yet.
Mark Dobson
July 25, 2013 at 5:21 pm[Stephen Nahroniak] “. I haven’t found that you can do that in X yet.”
Sutre you can.
If you highlight any parameter in the inspector you can then nudge nudge wink wink to your delight
I use the arrows for multitude of detailed adjustment particularly in the transform window and the color board
Stephen N.
July 25, 2013 at 5:30 pmHmm
So select the clip in the timeline to load it into the viewer
Highlight the parameter I want to change, lets say transform.
When I use the arrows, all it does is move the playhead left or right in the timeline -
Ronny Courtens
July 25, 2013 at 5:30 pmAs Mark says.
Highlight the parameter in the Inspector (click on its value) and use the Up and Down arrows to nudge.
OPTION+Up or Down arrows will increase or decrease the parameter by exactly 1 pixel.
