Activity Forums Adobe After Effects keyboard shortcut for keyframing?
  • keyboard shortcut for keyframing?
    Posted by Bobo007 on October 30, 2006 at 7:48 pm
    this question may be stupid but i cant seem to find out how to do it
    is there a keyboard shortcut for making a keyframe when on an attribute? I am tired of clicking the little yellow dot!
    I know that if I am on an attribute and then click the yellow dot and then progress down my timeline and then change the atttribute it will automatically make a keyframe. But is there a shortcut to make that first keyframe, so I dont have to click that yellow dot?
    thanks
    Michele Romano replied 11 years, 2 months ago 9 Members · 9 Replies
  • 9 Replies
  • Broken
    November 1, 2006 at 7:01 pm
    The keyboard shortcut for setting a position keyframe is option-p on a mac; i think it’s control-p on a windows machine. For opacity, it’s option-t.
    There are a whole bunch more of them. I STRONGLY suggest that you look them up in AE Help. That’s why it’s there… to help, y’know?
    Dave LaRonde
    Sr. Promotion Producer
    KCRG-TV
  • Jim Kanter
    November 3, 2006 at 3:44 pm
    On Mac use the OPTION key with the property shortcut key.
    On Win use the ALT key with the property shortcut key.
    A Anchor Point
    P Position
    R Rotation
    S Scale
    T Opacity
    are the most common. Check AE help for more.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Bobo007
    November 3, 2006 at 7:51 pm
    thanks!
  • Mathias Wolthuis
    June 7, 2012 at 11:00 am
    which is the property shortcut key?? does every keyboard have it??
  • David Cabestany
    January 15, 2014 at 10:22 pm
    What about a custom property, like a slider, for example?
  • Leon Earl
    January 11, 2015 at 12:19 am
    I’m having the same problem. What is the ‘property’ key on a Mac?
  • Erik Hill
    February 3, 2015 at 5:19 am
    Jim Kanter’s explanation is correct:
    A Anchor Point
    P Position
    R Rotation
    S Scale
    T Opacity
    For example, if you’re setting a keyframe for scale and you’re on a Mac press option + the S key, if you’re setting a keyframe for opacity on a Windows machine press Alt + the T key, etc.
    I was confused too but just happened to figure it out. Hope this helps!
    -Erik
    Video Beast
  • John Sollows
    April 17, 2015 at 12:15 pm
    alt + t just opens the edit menu on the top bar for me (adobe AE CC)
  • Michele Romano
    July 21, 2015 at 1:24 pm
    I had the same problem in finding the corresposponding hotkey in Windows.
    I realized that it is not alt+t/a/p/etc. but alt+shift+[the_needed_key].
    I hope this could help. It was a pain in the neck for me not beeing able to use it!
