Activity › Forums › Apple Final Cut Pro Legacy › Keyboard Final Cut
  • Keyboard Final Cut
    Posted by Natalia López on May 21, 2010 at 12:01 pm
    I'm working on a project with Final Cut 7. I'm using a keyboard logic. I do not get to stay saved the changes I make on the keyboard. During the same session, Whether maintaining the changes you've added, But once you power off the computer, The keyboard is again reset, But choose with ("keyboard load) configuration that I had saved. And the keyboard appears as if it made no changes huboese. Anyone know if there is any way that I am jumping?
    I am just:
    Customize keyboard / unlock the keypad / add changes and shortcuts / save as keyboard / and named it. I usually get a warning for the text change to Spanish keyboard iso, But I continue with the changes. I have already named my keyboard (keyboard x) and I get on the menu every time I go to tools / keyboard layout. Xy choose keyboard I get a configuration that lacks the changes I made earlier.
    Anyone can help me?
    Natalia
    Chuska Esteban replied 16 years, 1 month ago 2 Members · 1 Reply
  • Chuska Esteban
    August 10, 2010 at 9:22 am
    Hi Natalia:
    I think I have the same problem. I make the changes that I want to my keyboard and I save them with a name. Buy every time I open Final, I have to again go to the Menu and choose the keyboard that I have saved. A warning appears “That keyboard layout is for Spanish-ISO. If you import it into the current language, the keys may not match up properly” I say OK and now I can use the keyboard I saved. But when I open again Final Cut…I have again to choose it. It´s really annoying. Please. Can you tell me, what did you do? or anyone can help me? Thank you
