Activity Forums Maxon Cinema 4D Key framing a spline path over video
  • Key framing a spline path over video
    Posted by Greg Paterson on September 18, 2005 at 1:54 pm
    Key framing a spline path over video ….what is the right way to do this.?
    I have a DV clip in the luminace channel of a material assigned to a plane. The animation has been set for the full length of the clip.
    Over this I need to key frame the motion of a sphere along a spline path to match the hand position of the actor in the clip.
    The problem is as i step through the animation frames the video clip stays on frame one. I have to render the scene to see the animation at that particular animation key frame.
    Then when i attempt to create a spline what i see is the clip has reverted back to clip frame 1 despite being on a different animation key.
    I suppose what i need is a way to link the animation key to the video key so that as I step through the animation keys the video follows correctly frame by frame.
    I hope someone can guide me with this.
    Greg
    Greg Paterson replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
