  • Posted by Ivankphoto on November 17, 2005 at 6:48 pm
    Hello, I am new to FCP. I am key framing some still images. I start zoomed in to the photo and slowly move out. Towards the end of hte keyframe it speeds up. Does anyone know how make the whole key frame run smoothly at an even time. thanks, ivan K
    Todd Gillespie replied 20 years, 10 months ago 2 Members · 1 Reply
  • Todd Gillespie
    November 17, 2005 at 7:31 pm
    Usually FCP defaults to a linear move, so the zoom should have been the same speed all the way through. Sometimes a zoom looks like it speeds up, but actually just the image ‘looking’ faster due to the fact the size is closer to the screen. (not a good explaination)
    If you go to the motion tab, you can rt click (control click) the keyframe and choose ‘smooth’ This should fix it. But if it doesn’t then you have ‘key frame handles’ that will give you control of the speed in relationship to the keyframe.
    Good Luck,
    Todd at UCSB
    Television Production
