Activity Forums Adobe After Effects key frame interpolation – strange movement
  • key frame interpolation – strange movement
    Posted by Wim Roegels on July 17, 2005 at 7:38 pm
    Dear Masters,
    I have a tiny problem with two keyframes of a cam position.
    First I had a smooth move between two points. Fine. But than I wanted to pause the movement and inserted two linear keyframes with exact the same values. Unfortunatly there is still a movement inbetween … and I do not understand why.
    Can someone give a hint please?
    Steve Roberts replied 21 years, 2 months ago 3 Members · 3 Replies
  • Filip Vandueren
    July 17, 2005 at 9:49 pm
    There’s two types of interpolation: spatial (via what route does the animatio go from a to be) and in time (how does the speed of animation vary inbetween a and b).
    You need the spatial interpolation be set to linear, or toggle the “Hold Keyframe” option on the first keyframe.
    It’s all in the manual actually.
  • Wim Roegels
    July 18, 2005 at 3:03 am
    I am aware of the chapter in the manual, but both of them are spatial, so the interpolation should be linear. and with two keyframes with the same value i guessed, that there will be no movement – but there is.
  • Steve Roberts
    July 18, 2005 at 3:26 am
    Yesss … but keyframes for position, rotation or scale can have different spatial and temporal interpolations.
    Try making the first keyframe a hold keyframe, as Filip suggested.
    Steve
