Key combo for unconstrained re-size in playback window on Premiere Pro CS3?
I’m hoping there’s a shortcut or something for this: I often need to do an uncontrained resize in the playback panel.
I used to use FC Pro which let you shift-drag (or alt? I don’t remember) to do an unconstrained resize, but in Prem pro cs3 I’ve got to go to effects controls, expand Motion, untick Uniform Scale before doing my scale. I suppose I could untick ….
Here I go, I’ve just answered my question, but I’ll put it up in case it helps anyone else searching the web.
I untick Uniform Scale for the whole clip, then use shift-drag to resize when I want uniform scaling, and a normal drag when I want unconstrained resizing. Not perfect, but not bad…
Thaks for reading.
– Paddy
