Activity Forums Blackmagic Design Kernel Panics in FCP
  • Kernel Panics in FCP
    Posted by Matt Devries on January 24, 2007 at 11:49 pm
    If I have a clip in a different cocec and I try to cut it into a DV25 seq, then I get a kernel panic. This has happened when I tried to put HDV clips and DV50 clips into a DV25 sequence. If I switch over my A/V settings to the FCP NTSC DV preset, then I have no problems. But if I use the BlackMagic DV NTSC preset, then I get the kernel panics. The panics happend when I try to play the sequence after rendering the clips. Any ideas?
    Decklink SP
    Mac Pro 2.66 GHz
    3 GB RAM (I’ve checked RAM with Apple System Test)
    OS 10.4.8
    FCP 5.1.2
    Qucktime 7.1.3
    Blackmagic 5.9
    Matt Devries replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
