Activity › Forums › Apple Final Cut Pro Legacy › Ken Burns effect?
Ken Burns effect?
Posted by Nick Biggs on March 1, 2008 at 11:52 pmIs there an easy to create a Ken Burns effect inside FCP5?
David Mcgiffert replied 18 years, 6 months ago 6 Members · 8 Replies -
Zane Barker
March 2, 2008 at 4:16 amNot inside of FCP, to do it inside you have to manually set keyframes.
Whenever I do slideshows I use fotomagico and then bring the finished slideshow into FCP if needed.
Don’t let technology get in the way of your creativity!
Shane Ross
March 2, 2008 at 4:44 amAbsolutely you can do it in FCP.
Tutorial!
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Zane Barker
March 2, 2008 at 4:56 amOf course you can do it in FCP, however if all you are doing is a photo montage it is quite time consuming to manually do each photo. Using FCP is great for a couple, it will just take 10 times linger if you have 60 photos.
Great tutorial though, I just wish I could subscribe to all the cows FCP tutorials in a podcast.
David Mcgiffert
March 2, 2008 at 6:11 amZane I am a big fan of FotoMagico.
Does the slideshow import with the kind of quality
you can get out of the program itself?thanks,
David
Zane Barker
March 2, 2008 at 7:30 am[David McGiffert] “Does the slideshow import with the kind of quality
you can get out of the program itself? “Yea the trick is to export it using the same setting as the timeline you are working in in FCP. For example if you are editing DVCPRO HD then you export the slides show as a DVCPRO HD quicktime. Then when you bring it in to FCP you do not have to render, and you can also lay it back to tape as a master.
Chris Poisson
March 2, 2008 at 3:19 pmThird vote for Fotomagico, what a great tool and great timesaver. Absolutely the best way to go for this.
Have a wonderful day.
Martial Bachoffner
March 2, 2008 at 4:52 pmPhoto to Movie is great for that.
https://www.lqgraphics.com/Regards,
MartialVancouver Island Final Cut Pro User Group
Martial Bachoffner
Founder and Administrator -
David Mcgiffert
March 2, 2008 at 5:00 pmThanks Zane, that’s great to know.
I have worked a little with the FotoMagico folks
and they were responsive and helpful.
I’m glad their product is doing well, they deserve it.David
