John Rofrano
January 26, 2011 at 3:10 am[Terry Fein] “Maybe I didn’t get far enough into the video tutorial, but how you you apply the montage settings to only a portion of the timeline? I want to start the pan and zoom effects at a certain point in the project.”
Make a timeline selection of the are you’d like to fill with the photo montage and create a Region (R key) and name it. Then when you use Photo Montage, check the Fit to Region option and only make the montage in that region. You can have it automatically calculate how long each event should be to fill that region or manual specify the duration if you’d like.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Terry Fein
January 26, 2011 at 3:53 amThanks. I will try this. In the meantime, I managed to accomplish what I wanted by creating two separate video tracks and applying the montage to one of them–admittedly, a less elegant way of doing it. I have been using Vegas Pro for a fair amount of time, but still have significant knowledge gaps.
Terry
