Activity › Forums › Apple Final Cut Pro Legacy › Ken Burns effect
Ken Burns effect
Posted by Holly Arnold on September 23, 2009 at 11:14 amHow would i be able to create the same visual as the Ken Burns effect from IMovies on an image in Final Cut?
Chris Poisson replied 16 years, 11 months ago 5 Members · 6 Replies -
Holly Arnold
September 23, 2009 at 11:20 amI don’t think i will be able to get access to either of those two programs. How is it done in FCP?
Tom Wolsky
September 23, 2009 at 11:57 amhttps://www.fcpbook.com/Motion_Control_in_FCE.html
This should get you going. It’s designed for FCE users, but it’s basically the same in FCP.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Niclas Bahn
September 23, 2009 at 12:53 pmHi Holly,
Have a look at our free Pan and Zoom plug-in to create “Ken Burns” animations inside FCP, Motion and AE. Also works in Final Cut Express!
https://www.noiseindustries.com/fxfactory/panandzoom/
FxFactory Tutorial – Pan and Zoom Freebie from Noise Industries on Vimeo.
Ben Holmes
September 23, 2009 at 1:59 pmPut the clip in the timeline, double click to open it in the viewer, go to the motion tab on the clip, put playhead or first frame. Click the diamond next to scale to set a keyframe. Move sliders for scale as required. Click on the diamond by position, then the cross for position as required (drag cross to canvas to move footage). Move playhead to last frame of clip, repeat process (for end of move – will not require you to press diamond button as new keyframes are automagically created now). Done.
If you want dissolves between clips, note that the two keyframes need to be at the first and last frames of the dissolves, which will be earlier/later than with cuts, so apply the dissolve first.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producerhttps://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Chris Poisson
September 23, 2009 at 4:22 pmWhen using the Motion window as Ben suggests, using travel mattes is a great way to go. It gets you around the keyframe issues on the dissolves.
https://library.creativecow.net/articles/poisson_chris/FCPTravelMattes.php
