Activity Forums Adobe Premiere Pro KEM Roll Crashes in Premiere Pro CC
  • KEM Roll Crashes in Premiere Pro CC
    Posted by Ally Shore on July 19, 2013 at 2:55 am
    I’m trying to work with KEM rolls.
    I create a sequence with all of my interview footage. I then sync this sequence in pluraleyes. I take the new synced sequence and add markers & comments to log the interview. I then move that sequence into the source monitor. Then locate an in and out and do an overwrite into a new sequence. I’ve made sure that the “use clips not nest” button is clicked. It sometimes works once, but most often it just crashes the program. I’m using the latest July update of Premiere Pro CC. I have no effects on the sequence other than a resize (the interview sequence is a 1920×1080 and the the new sequence is a 1080×720).
    Anyone else having this problem? If not, anyone have any ideas?
    Ally
    Ally Shore replied 13 years, 2 months ago 2 Members · 2 Replies
  • David Mcgavran
    July 19, 2013 at 5:47 am
    [Ally Shore] “Anyone else having this problem? If not, anyone have any ideas?”
    Hi Ally,
    We have one open issue here we are investigating. Not sure if it is the same. Can you send crash reports?
    Dave
    David McGavran, Adobe Systems Incorporated
    Senior Engineering Manager Adobe Premiere Pro
  • Ally Shore
    July 19, 2013 at 6:16 am
    Process: Adobe Premiere Pro CC [5633]
    Path: /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/MacOS/Adobe Premiere Pro CC
    Identifier: com.adobe.AdobePremierePro
    Version: 7.0.1 (7.0.1)
    Code Type: X86-64 (Native)
    Parent Process: launchd [177]
    Date/Time: 2013-07-18 19:44:35.670 -0700
    OS Version: Mac OS X 10.7.5 (11G63b)
    Report Version: 9
    Interval Since Last Report: 336080 sec
    Crashes Since Last Report: 8
    Per-App Interval Since Last Report: 2698 sec
    Per-App Crashes Since Last Report: 3
    Anonymous UUID: DDA6BE09-DBD1-4375-9920-8356E1F8BD16
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x00000001025d46f8
    VM Regions Near 0x1025d46f8:
    __TEXT 0000000101803000-0000000102578000 [ 13.5M] r-x/rwx SM=COW /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
    –> __DATA 0000000102578000-00000001025fc000 [ 528K] rw-/rwx SM=COW /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
    __DATA 00000001025fc000-000000010260f000 [ 76K] rw-/rwx SM=PRV /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
    Application Specific Information:
    objc[5633]: garbage collection is OFF
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 ??? 0x00000001025d46f8 vtable for BE::VideoClipTrackItem + 856
    1 com.adobe.Backend.framework 0x0000000101e3a14f BE::TrackItemSelectionFactory::ApplySourceMappingsToTrackItemSelection(ASL::InterfaceRef, std::map const&, std::map const&) + 2079
    2 com.adobe.Backend.framework 0x0000000101e3d302 BE::TrackItemSelectionFactory::CreateExplodedSequenceSelection(ASL::InterfaceRef const&, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, std::map const&, std::map const&, dvamediatypes::TickTime*, dvamediatypes::TickTime*) + 3218
    3 com.adobe.Backend.framework 0x0000000101e3d8a7 BE::TrackItemSelectionFactory::CreateSelection(ASL::InterfaceRef, dvamediatypes::FrameRate, ASL::InterfaceRef, std::map const&, std::map const&, ASL::InterfaceRef, bool, BE::TrackItemSelectionMode::Type) + 1303
    4 com.adobe.Mezzanine.framework 0x0000000105e1b25b MZ::TrackItemSelection::CreateSelection(ASL::InterfaceRef, dvamediatypes::FrameRate, ASL::InterfaceRef, std::map const&, std::map const&, ASL::InterfaceRef, bool, BE::TrackItemSelectionMode::Type) + 203
    5 com.adobe.Mezzanine.framework 0x0000000105d5c40b MZ::SequenceActions::GenerateMasterClip4PointTrackItemPairUsingSourceTracks(ASL::InterfaceRef, ASL::InterfaceRef, std::map const&, std::map const&, bool, bool, ASL::InterfaceRef&, ASL::InterfaceRef&, ASL::InterfaceRef&, bool) + 523
    6 com.adobe.Mezzanine.framework 0x0000000105d5a65f MZ::SequenceActions::QueryInsertItem(ASL::InterfaceRef, ASL::InterfaceRef, bool, bool, bool, bool, bool&, bool, bool, bool) + 1103
    7 com.adobe.Mezzanine.framework 0x0000000105d5a9af MZ::SequenceActions::QueryInsertItem(ASL::InterfaceRef, ASL::InterfaceRef, bool, bool, bool, bool, bool&, bool) + 127
    8 com.adobe.HandlerSourceMonitor.framework 0x000000010b0a4029 HandlerSourceMonitor::SourceMonitorView::InsertOrOverlay(int, bool, bool) + 2953
    9 com.adobe.HandlerSourceMonitor.framework 0x000000010b0a540e HandlerSourceMonitor::SourceMonitorView::OnOverlay(UIF::Command const&) + 174
    10 com.adobe.HandlerSourceMonitor.framework 0x000000010b0cdd1a HandlerSourceMonitor::SourceMonitorView::ObeyCommand(UIF::Command const&) + 1722
    11 com.adobe.UIFramework.framework 0x00000001045cc7b5 UIF::Commander::PostCommandInner(UIF::Command const&, bool&) + 853
    12 com.adobe.Frontend.framework 0x0000000100067e4c FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0) + 76
    13 com.adobe.UIFramework.framework 0x00000001045cc3df UIF::Commander::PostCommand(UIF::Command const&) + 111
    14 com.adobe.UIFramework.framework 0x000000010467bd4a UIF::ShortcutManager::TranslateKeyboardEvent(UIF::KeySpec const&, bool, bool) const + 698
    15 com.adobe.UIFramework.framework 0x000000010467e8c2 UIF::ShortcutManager::DispatchKeyboardEvent(dvaui::ui::KeyboardEvent const&, bool) const + 338
    16 com.adobe.UIFramework.framework 0x00000001046ee21c non-virtual thunk to UIF::TopLevelWindowImpl::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 124
    17 com.adobe.dvaui.framework 0x0000000103d8e6d0 dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 496
    18 com.adobe.dvaui.framework 0x0000000103df68bd dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Event*) + 157
    19 com.adobe.dvaui.framework 0x0000000103e004bf dvaui::ui::OS_Window::UI_DispatchEvent(dvaui::ui::OS_Event*) + 79
    20 com.adobe.dvaui.framework 0x0000000103e15ba4 boost::detail::function::function_obj_invoker0::invoke(boost::detail::function::function_buffer&) + 36
    21 com.adobe.dvaui.framework 0x0000000103d03bf7 int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, bool*) + 71
    22 com.adobe.Frontend.framework 0x0000000100067e4c FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0) + 76
    23 com.adobe.dvaui.framework 0x0000000103d03aac bool dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 140
    24 com.adobe.dvaui.framework 0x0000000103d02c6d bool dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 125
    25 com.adobe.dvaui.framework 0x0000000103e0902e -[DVAMacPanelWindow performKeyEquivalent:] + 206
    26 com.apple.AppKit 0x00007fff9037bd7a -[NSApplication _handleKeyEquivalent:] + 611
    27 com.apple.AppKit 0x00007fff90274e86 -[NSApplication sendEvent:] + 4282
    28 com.adobe.dvaui.framework 0x0000000103e0716e -[DVAMacApplication sendEvent:] + 622
    29 com.adobe.Frontend.framework 0x00000001000bdeb7 -[PremiereCocoaMacApplication sendEvent:] + 311
    30 com.apple.AppKit 0x00007fff9020ba0e -[NSApplication run] + 555
    31 com.adobe.Frontend.framework 0x00000001000bf7ed FE::MacApplication::RunSelf() + 45
    32 com.adobe.Frontend.framework 0x0000000100045706 FE::Application::Run(std::basic_string const&) + 6438
    33 com.adobe.Frontend.framework 0x00000001000c0ef0 FE::AppMain(ASL::ObjectPtr const&, std::basic_string const&, int, void*) + 304
    34 com.adobe.Frontend.framework 0x00000001000c7552 FE::Run(ASL::ObjectPtr const&, std::basic_string const&, int) + 754
    35 com.adobe.AdobePremierePro 0x0000000100001ae1 main + 625
    36 com.adobe.AdobePremierePro 0x0000000100001864 start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0 libsystem_kernel.dylib 0x00007fff897ca7e6 kevent + 10
    1 libdispatch.dylib 0x00007fff93068786 _dispatch_mgr_invoke + 923
    2 libdispatch.dylib 0x00007fff93067316 _dispatch_mgr_thread + 54
    Thread 2:
    1 com.adobe.dvatransport.framework 0x0000000100c91624 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue&) + 228
    2 com.adobe.dvatransport.framework 0x0000000100c91214 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::thread_info&, boost::asio::detail::op_queue&, boost::system::error_code const&) + 340
    3 com.adobe.dvatransport.framework 0x0000000100c90ccd boost::asio::detail::task_io_service::run(boost::system::error_code&) + 285
    4 com.adobe.dvatransport.framework 0x0000000100c81c92 SkyConnectionEnv::MainLoop() + 162
    5 com.adobe.dvatransport.framework 0x0000000100c81879 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
    6 com.adobe.boost_threads.framework 0x00000001002576d4 thread_proxy + 164
    7 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    8 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 3:
    0 libsystem_kernel.dylib 0x00007fff897c9bca __psynch_cvwait + 10
    1 libsystem_c.dylib 0x00007fff8f8ca274 _pthread_cond_wait + 840
    2 com.adobe.dvatransport.framework 0x0000000100c911dc boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::thread_info&, boost::asio::detail::op_queue&, boost::system::error_code const&) + 284
    4 com.adobe.dvatransport.framework 0x0000000100c90b9a boost::asio::detail::posix_thread::func::run() + 42
    5 com.adobe.dvatransport.framework 0x0000000100c91b63 boost_asio_detail_posix_thread_function + 19
    6 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    7 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 4:
    2 com.apple.CoreServices.CarbonCore 0x00007fff8c8f6a5e TSWaitOnCondition + 106
    3 com.apple.CoreServices.CarbonCore 0x00007fff8c888ea6 TSWaitOnConditionTimedRelative + 127
    4 com.apple.CoreServices.CarbonCore 0x00007fff8c8cde81 MPWaitOnQueue + 181
    5 com.adobe.dvacore.framework 0x00000001003449fb dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 171
    6 com.adobe.dvacore.framework 0x0000000100342aec dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 172
    7 com.adobe.dvacore.framework 0x0000000100340159 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 265
    8 com.adobe.boost_threads.framework 0x00000001002576d4 thread_proxy + 164
    9 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    10 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 5:
    1 libsystem_c.dylib 0x00007fff8f8ca2a6 _pthread_cond_wait + 890
    2 com.apple.CoreServices.CarbonCore 0x00007fff8c888ec4 TSWaitOnConditionTimedRelative + 157
    3 com.apple.CoreServices.CarbonCore 0x00007fff8c8cde81 MPWaitOnQueue + 181
    4 com.adobe.dvacore.framework 0x00000001003449fb dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 171
    5 com.adobe.dvacore.framework 0x0000000100342aec dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 172
    6 com.adobe.dvacore.framework 0x0000000100340159 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9function0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 265
    7 com.adobe.boost_threads.framework 0x00000001002576d4 thread_proxy + 164
    8 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    9 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 6:
    Thread 7:
    Thread 8:
    0 libsystem_kernel.dylib 0x00007fff897c867a mach_msg_trap + 10
    1 libsystem_kernel.dylib 0x00007fff897c7d71 mach_msg + 73
    2 com.apple.CoreFoundation 0x00007fff9229c50c __CFRunLoopServiceMachPort + 188
    3 com.apple.CoreFoundation 0x00007fff922a4c74 __CFRunLoopRun + 1204
    4 com.apple.CoreFoundation 0x00007fff922a4486 CFRunLoopRunSpecific + 230
    5 com.apple.AVCVideoServices 0x000000011e929a62 _ZN3AVSL27AVCVideoServicesThreadStartEPNS_28AVCVideoServicesThreadParamsE + 194
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    2 com.apple.CoreServices.CarbonCore 0x00007fff8c8f4c02 TS_exception_listener_thread + 100
    3 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    4 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 13:
    0 libsystem_kernel.dylib 0x00007fff897c9e42 __semwait_signal + 10
    1 libsystem_c.dylib 0x00007fff8f87cdea nanosleep + 164
    2 com.adobe.ScriptLayerPPro.framework 0x00000001068917d8 ScObjects::Thread::wait(unsigned int) + 56
    3 com.adobe.ScriptLayerPPro.framework 0x000000010687ccbe ScObjects::BridgeTalkThread::run() + 174
    4 com.adobe.ScriptLayerPPro.framework 0x0000000106891375 ScObjects::Thread::go(void*) + 165
    5 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    6 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 14:
    0 libsystem_kernel.dylib 0x00007fff897c9d7a __recvfrom + 10
    1 ServiceManager-Launcher.dylib 0x0000000126010231 0x125ff8000 + 98865
    2 ServiceManager-Launcher.dylib 0x000000012600f5d6 0x125ff8000 + 95702
    3 ServiceManager-Launcher.dylib 0x000000012600e678 0x125ff8000 + 91768
    4 ServiceManager-Launcher.dylib 0x000000012600e6e6 0x125ff8000 + 91878
    5 ServiceManager-Launcher.dylib 0x00000001260092e4 0x125ff8000 + 70372
    6 ServiceManager-Launcher.dylib 0x0000000126009cfe 0x125ff8000 + 72958
    7 ServiceManager-Launcher.dylib 0x0000000126009c0b 0x125ff8000 + 72715
    8 ServiceManager-Launcher.dylib 0x000000012600d36e 0x125ff8000 + 86894
    9 ServiceManager-Launcher.dylib 0x000000012600d4b2 0x125ff8000 + 87218
    10 ServiceManager-Launcher.dylib 0x000000012600d26d 0x125ff8000 + 86637
    11 ServiceManager-Launcher.dylib 0x000000012600d1e6 0x125ff8000 + 86502
    12 ServiceManager-Launcher.dylib 0x0000000125ffb916 0x125ff8000 + 14614
    13 ServiceManager-Launcher.dylib 0x0000000125fffb05 0x125ff8000 + 31493
    14 ServiceManager-Launcher.dylib 0x000000012600de46 0x125ff8000 + 89670
    15 ServiceManager-Launcher.dylib 0x000000012600fef3 0x125ff8000 + 98035
    16 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    17 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 15:: com.apple.CFSocket.private
    0 libsystem_kernel.dylib 0x00007fff897c9df2 __select + 10
    1 com.apple.CoreFoundation 0x00007fff922edc8b __CFSocketManager + 1355
    2 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    3 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 16:
    1 com.adobe.MediaFoundation.framework 0x000000010126d730 _ZN2MF22DirectoryChangeMonitor12_GLOBAL__N_1L20EventQueueThreadProcEPv + 544
    Thread 17:
    2 com.adobe.ape.engine 0x00000001b34cd3dd APXGetHostAPI + 2516301
    3 com.adobe.ape.engine 0x00000001b327b5c1 APXGetHostAPI + 83761
    4 com.adobe.ape.engine 0x00000001b34cd4a1 APXGetHostAPI + 2516497
    5 com.adobe.ape.engine 0x00000001b34cd51a APXGetHostAPI + 2516618
    6 com.adobe.ape.engine 0x00000001b34cd649 APXGetHostAPI + 2516921
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    5 com.apple.CoreMediaIO 0x00007fff8c1e7fe9 CMIO::DAL::RunLoop::OwnThread(void*) + 159
    6 com.apple.CoreMediaIO 0x00007fff8c1de15a CAPThread::Entry(CAPThread*) + 98
    Thread 22:
    2 com.adobe.ape.engine 0x00000001b34cd3a0 APXGetHostAPI + 2516240
    3 com.adobe.ape.engine 0x00000001b34e55ab APXGetHostAPI + 2615067
    Thread 23:
    3 com.adobe.ape.engine 0x00000001b3660073 APXGetHostAPI + 4166115
    Thread 24:: com.apple.NSURLConnectionLoader
    5 com.apple.Foundation 0x00007fff8f57dfd7 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 335
    6 com.apple.Foundation 0x00007fff8f57272a -[NSThread main] + 68
    7 com.apple.Foundation 0x00007fff8f5726a2 __NSThread__main__ + 1575
    Thread 25:: com.apple.audio.IOThread.client
    2 com.apple.audio.CoreAudio 0x00007fff90198eb3 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, unsigned int) + 93
    3 com.apple.audio.CoreAudio 0x00007fff90198f05 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 37
    4 com.apple.audio.CoreAudio 0x00007fff90192568 HALC_ProxyIOContext::IOWorkLoop() + 888
    5 com.apple.audio.CoreAudio 0x00007fff90192151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
    6 com.apple.audio.CoreAudio 0x00007fff9019200c HALB_IOThread::Entry(void*) + 78
    Thread 26:
    2 com.mainconcept.mc.bc.dec.avc 0x000000011fcb8d9d h264in_Video_GetAPIExt + 238429
    3 com.mainconcept.mc.bc.dec.avc 0x000000011fc31785 open_h264in_Video_stream + 341877
    4 libsystem_c.dylib 0x00007fff8f8c68bf _pthread_start + 335
    5 libsystem_c.dylib 0x00007fff8f8c9b75 thread_start + 13
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    Thread 34:
    Thread 35:
    0 libsystem_kernel.dylib 0x00007fff897ca192 __workq_kernreturn + 10
    1 libsystem_c.dylib 0x00007fff8f8c8594 _pthread_wqthread + 758
    2 libsystem_c.dylib 0x00007fff8f8c9b85 start_wqthread + 13
    Thread 36:
    Thread 37:
    Thread 38:
    Thread 39:
    Thread 40:
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    Thread 56:
    Thread 57:
    Thread 58:
    Thread 59:
    Thread 60:
    Thread 61:
    Thread 0 crashed with X86 Thread State (64-bit):
    rax: 0x000000017f7748c0 rbx: 0x00007fff5fbfd828 rcx: 0x000000017f76bc20 rdx: 0x000000017f76bc20
    rdi: 0x000000012b543500 rsi: 0x00007fff5fbfd830 rbp: 0x00007fff5fbfd790 rsp: 0x00007fff5fbfd6d8
    r8: 0x00000001025ce250 r9: 0x00000001025d23f0 r10: 0x0000000000000000 r11: 0x000000017f7c2268
    r12: 0x000000017f7c2190 r13: 0x000000017f7748c0 r14: 0x000000017f76bc20 r15: 0x00007fff5fbfd828
    rip: 0x00000001025d46f8 rfl: 0x0000000000010206 cr2: 0x00000001025d46f8
    Logical CPU: 6
    Binary Images:
    0x100000000 – 0x100002ff7 +com.adobe.AdobePremierePro (7.0.1 – 7.0.1) <80428C19-437C-3C11-B077-149FDBA3CA69> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/MacOS/Adobe Premiere Pro CC
    0x10000a000 – 0x10000cfff +com.adobe.AdobeCrashReporter (7.0 – 7.0.1) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
    0x100012000 – 0x100124ff7 +com.adobe.Frontend.framework (7.0.1 – 7.0.1.105) <5CE7F168-192F-374E-ABC2-6549458B632E> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
    0x10022a000 – 0x10022dff7 +com.adobe.PRM.framework (7.0.1 – 7.0.1.105) <546437DC-6F88-3C3E-ADFC-76109E79B39A> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
    0x100239000 – 0x10023fff7 +com.adobe.boost_date_time.framework (7.0.1 – 7.0.1.105) <91905282-2190-3003-B0FA-6D74B074F964> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
    0x100256000 – 0x100264fff +com.adobe.boost_threads.framework (7.0.1 – 7.0.1.105) <26B263C9-5DBF-353F-BA5A-FD21A37ACCDC> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
    0x100288000 – 0x1004d2ff7 +com.adobe.dvacore.framework (7.0.1 – 7.0.1.105) <745433FB-D4E5-307E-A40F-E48055AFBC64> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
    0x100709000 – 0x100737fff +com.adobe.dvamediatypes.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
    0x10076b000 – 0x1007b6ff7 +com.adobe.ASLFoundation.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
    0x100822000 – 0x100871fff +com.adobe.headlights.LogSessionFramework (??? – 2.1.2.1756) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
    0x1008a7000 – 0x100996fff +com.adobe.amtlib (7.0.0.169 – 7.0.0.169) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x1009a9000 – 0x100a16fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 14 – 79.151805) <13002997-BD96-3A65-BFEC-09C9EB786A35> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
    0x100a49000 – 0x100b55fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 51 – 79.151805) <596FEA1A-3627-30B3-8AC4-BE1885788307> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
    0x100c03000 – 0x100c11fff +com.adobe.ASLMessaging.framework (7.0.1 – 7.0.1.105) <90FA5655-D3BD-37CC-893B-1D10B47C846A> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
    0x100c2c000 – 0x100c2dff7 +com.adobe.Memory.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
    0x100c34000 – 0x100c42fff +com.adobe.ASLUnitTesting.framework (7.0.1 – 7.0.1.105) <1F7A1F5C-5A93-3682-8D3A-6AC00ABC1080> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
    0x100c5e000 – 0x100c62fff +com.adobe.boost_system.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
    0x100c6b000 – 0x100cccff7 +com.adobe.dvatransport.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
    0x100d67000 – 0x100d8ffff +com.adobe.dvamarshal.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
    0x100dd8000 – 0x100fc8ff7 +com.adobe.dynamiclink.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
    0x101229000 – 0x1012abfff +com.adobe.MediaFoundation.framework (7.0.1 – 7.0.1.105) <7A8EAA02-F589-3EF2-8C94-A13C4CCA16EA> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
    0x101362000 – 0x1013eaff7 +com.adobe.AudioRenderer.framework (7.0.1 – 7.0.1.105) <23FC17AE-84FD-3664-8969-9E8EA6AA5266> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
    0x1014a8000 – 0x101569ff7 +com.adobe.dvacaptioning.framework (7.0.1 – 7.0.1.105) <206CA25B-CAE8-3AA1-9B72-EA5C1D13ADE0> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
    0x101621000 – 0x101678ff7 +com.adobe.dvatemporalxmp.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
    0x1016b1000 – 0x1016bcfff +com.adobe.boost_signals.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
    0x1016d4000 – 0x10174aff7 +com.adobe.dvametadata.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
    0x101803000 – 0x102577ff7 +com.adobe.Backend.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
    0x1032cd000 – 0x103308ff7 +com.adobe.MLFoundation.framework (7.0.1 – 7.0.1.105) <35C33D13-A925-3F9E-9597-C85F9DF72995> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
    0x10336e000 – 0x103468fff +com.adobe.ImageRenderer.framework (7.0.1 – 7.0.1.105) <293044BE-AB0F-390E-B4F9-57CA273A599A> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
    0x103600000 – 0x103676fff +com.adobe.VideoFrame.framework (7.0.1 – 7.0.1.105) <78BCC5FF-1B2A-37BE-B450-433E167FAD9D> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
    0x1036f4000 – 0x10372dff7 +com.adobe.PluginSupport.framework (7.0.1 – 7.0.1.105) <8F264884-A4E7-3BE4-A0A6-BED7F99C0E8C> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
    0x103775000 – 0x10379cfff +com.adobe.SweetPeaSupport.framework (7.0.1 – 7.0.1.105) <1D03A3F8-1BEC-3497-BDFE-0A80B3DDCE62> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
    0x1037db000 – 0x103821ff7 +com.adobe.TransmitHost.framework (7.0.1 – 7.0.1.105) <77767F08-362A-382C-8C3C-0731F343EB9C> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
    0x103885000 – 0x10393cfef +com.adobe.atlaudio.framework (7.0.1 – 7.0.1.105) <2271A302-DADB-3DD6-9670-468D1C7728C5> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
    0x103964000 – 0x1039adfff +com.adobe.AudioSupport.framework (7.0.1 – 7.0.1.105) <3AA0C2C6-D000-3B2E-BA37-C88800A92AC5> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
    0x103a00000 – 0x103a02fff +com.adobe.MediaUtils.framework (7.0.1 – 7.0.1.105) <0538DBCE-11AF-3A8B-8644-1565D4D1B819> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
    0x103a0a000 – 0x103a3dff7 +com.adobe.AudioFilterHost.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
    0x103a8b000 – 0x103acbff7 +com.adobe.AudioFilters.framework (7.0.1 – 7.0.1.105) <4A79FF2B-147C-3CF3-8EF2-5BDCC36B2C06> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
    0x103b2d000 – 0x103fa5fff +com.adobe.dvaui.framework (7.0.1 – 7.0.1.105) <5C1F4098-AA95-3FFB-994D-C4D0CAB6E2B7> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
    0x104593000 – 0x104816ff7 +com.adobe.UIFramework.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
    0x104b9d000 – 0x104ca9fff +com.adobe.VideoRenderer.framework (7.0.1 – 7.0.1.105) <7D5C852E-7C59-3E64-A8EC-DF0A083DAD49> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
    0x104df6000 – 0x104f75ff7 +com.adobe.ImporterHost.framework (7.0.1 – 7.0.1.105) <897F310F-B8CC-3D92-8428-D3072442E3F1> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
    0x10511e000 – 0x1051f3ff7 +com.adobe.ExporterHost.framework (7.0.1 – 7.0.1.105) <58525908-2E84-31B1-A696-5B86249E904E> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
    0x1052e7000 – 0x105359ff7 +com.adobe.PlayerHost.framework (7.0.1 – 7.0.1.105) <87E44E74-D96A-339E-9D3F-054E77E3F606> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
    0x1053f2000 – 0x10545bff7 +com.adobe.RecorderHost.framework (7.0.1 – 7.0.1.105) <70E2A8E0-4755-3E04-B911-1A2F9E778600> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
    0x1054e6000 – 0x1054f7fff +com.adobe.ProjectConverterHost.framework (7.0.1 – 7.0.1.105) <606B740C-DAA9-3823-A65B-F442B376D8C3> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
    0x105519000 – 0x1055fbff7 +com.adobe.VideoFilterHost.framework (7.0.1 – 7.0.1.105) <1EC541F5-0940-3410-8593-7F3B25D7BB9C> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
    0x1056e2000 – 0x1056f6ff7 +com.adobe.ProjectSupport.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
    0x105720000 – 0x1057e3ff7 +com.adobe.AMEWrapper.framework (7.0.1 – 7.0.1.105) <4E2A7623-A2CE-3EED-9FC7-6B41704E8C02> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
    0x105898000 – 0x105987fff +com.adobe.EncoderHost.framework (7.0.1 – 7.0.1.105) <91F3E228-1209-3396-8202-7C8D47F21A6D> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
    0x105a8a000 – 0x10614afff +com.adobe.Mezzanine.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
    0x106646000 – 0x1066f4ff7 +com.adobe.dvaworkspace.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
    0x1067fe000 – 0x1068f9ff7 +com.adobe.ScriptLayerPPro.framework (7.0.1 – 7.0.1.105) <0C49C4AB-F182-36C7-8CAF-012E5D636EBA> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
    0x1069f3000 – 0x106ab1ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.5 – 4.5.5.30707) <47137B86-90F2-3F47-A696-8C918A43BFC3> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
    0x106b01000 – 0x106bacff7 +com.adobe.AdobeScCore (ScCore 4.5.5 – 4.5.5.30707) <5EAD59E8-D05D-3E95-B1E0-4C96FF4329C9> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
    0x106bf1000 – 0x106d66fff +com.adobe.ScriptLayerPProQE.framework (7.0.1 – 7.0.1.105) <1589B20C-90CE-37B7-A6FE-33BFA7D0A780> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
    0x107049000 – 0x1070deff7 +com.adobe.PProDynamicLinkServer.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkServer
    0x10721c000 – 0x10724dff7 +com.adobe.PrRegistration.framework (7.0.1 – 7.0.1.105) <00BC39DC-F89C-3744-8E67-B3E8C4ADD144> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
    0x10727f000 – 0x10733bff7 +com.adobe.dvaeve.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
    0x1074ab000 – 0x107802fff +com.adobe.Dialogs.framework (7.0.1 – 7.0.1.105) <775A666E-C83A-3EB1-8B19-C7BE15228B85> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
    0x107b49000 – 0x107b9bff7 +com.adobe.BravoInitializer.framework (7.0.1 – 7.0.1.105) <8F18015A-3D26-3D7E-BAC4-B5B3660451CB> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
    0x107c16000 – 0x107d5afff +com.adobe.ACE (AdobeACE 2.20.02.30665 – 2.20.02.30665) <73C9699B-5EDC-3FDC-82FF-738C99AA840F> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
    0x107d6d000 – 0x1080a0ff7 +com.adobe.AGM (AdobeAGM 4.30.18.30665 – 4.30.18.30665) <4E87DA88-AEE3-36A5-8A76-4DFA93F58BE8> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
    0x10810c000 – 0x108129fff +com.adobe.BIB (AdobeBIB 1.2.03.30665 – 1.2.03.30665) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
    0x108131000 – 0x108441ff7 +com.adobe.CoolType (AdobeCoolType 5.13.00.30665 – 5.13.00.30665) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
    0x108489000 – 0x1084d8ff7 +com.adobe.MediaCoreUI.framework (7.0.1 – 7.0.1.105) <2123AF38-3E25-33D1-8700-99A0FE535E23> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
    0x108541000 – 0x1086fdfff +com.adobe.SettingsUI.framework (7.0.1 – 7.0.1.105) <190976FC-8002-39BD-A9C4-562E0A37B1A4> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
    0x108936000 – 0x108b3ffff +com.adobe.HSL.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
    0x108d84000 – 0x108e36ff7 +com.adobe.GPUFoundation.framework (7.0.1 – 7.0.1.105) <7CDBDD65-7898-3ED0-ACD8-8C60A8879016> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
    0x108ef8000 – 0x108fbafff +com.adobe.exo.framework (7.0.1 – 7.0.1.105) <2CC82ADA-1175-3AD0-99C1-E423FADE56F2> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
    0x109112000 – 0x109132fff +com.adobe.CSXSManager.framework (7.0.1 – 7.0.1.105) <655F63FE-0442-3AEA-8D74-52E05F3871B0> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
    0x10916b000 – 0x1097e9fdf +com.adobe.PlugPlug (4.0.1.34 – 4.0.1.34) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
    0x109dd2000 – 0x109e04fff +com.adobe.HandlerAudioMiniMixer.framework (7.0.1 – 7.0.1.105) /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMixer
    0x109e48000 – 0x109eedfff +com.adobe.HandlerAudioMixer.framework (7.0.1 – 7.0.1.105) <95845E69-9B31-3767-BFA1-AB48304C9891> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
    0x109fa7000 – 0x10a000ff7 +com.adobe.HandlerAudioClipMixer.framework (7.0.1 – 7.0.1.105) <9D242D49-64AA-3B08-BE5A-AACEEB4FD08A> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipMixer
    0x10a080000 – 0x10a0d6ff7 +com.adobe.HandlerCaptions.framework (7.0.1 – 7.0.1.105) <408CE774-0456-3F95-9DDE-36E0E3073B4A> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
    0x10a157000 – 0x10a1d5ff7 +com.adobe.HandlerCapture.framework (7.0.1 – 7.0.1.105) <824666CD-831E-3380-A071-34CBCF082DDE> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
    0x10a269000 – 0x10a2acff7 +com.adobe.HandlerEditToTape.framework (7.0.1 – 7.0.1.105) <79403AE9-C1AD-3F27-86F9-F0B7C896E4D5> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
    0x10a310000 – 0x10a33dfff +com.adobe.HandlerCSXS.framework (7.0.1 – 7.0.1.105) <326D94D2-241C-3AE7-A127-36D2787C8AC2> /Applications/Adobe Premiere Pro CC/Adobe Premiere Pro CC.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/Handle
